The Dave Method
The Dave Method is the clever use of components popularized by @DaveR to avoid the tiny face issue.
Sketchup fails to form faces when edge segments get down around the 1/1000" mark. However, tiny faces can exist so the workaround has generally been to scale up your geometry, edit it, then scale back down.
This works, but can lead to some issues.
The Dave Method leverages the power of components to make life easier.
The basic concept is, you start with a component set at the size you want, then you make a copy of that component and scale it up (this can be a random amount), you then edit the large component and those edits will be reflected in the original. You can then simply delete the large component, thus avoiding scaling down problems.
Here are two examples of how the edits work.
1mmRound
Another common example, spheres have holes in the top.
Dave%20Method
A thread example.
Tiny%20Thread
Could you help me with modeling a screw?
Drilling holes, an old topic and new example
Can someone tell me why I can't punch holes though this with solid tools
How to fix this weird zooming :(
What did I do wrong?
Need a little help with arcs and pull up tool please
3D Modelling Cable (Coiling)
Cant get threads on curved surface
3 way joint out of cylinders
Creating a Solid in Compound Corners
How can I do this piece of modelling?
Why is the union of solids not a solid
Flat faces on a cylinder that tapers?
STL Question
Material assignment & multi-level components
Round bottom indentation help
How do I modify to make a pulley
Trouble with Solid Group for 3D Printing
I just can't get Follow Me to work right!
Polylines with real arcs for CNC Router?
Unable to Make a [Somewhat] Complex Model Solid
SolidInspector reads all shiny but outer shell does not
Need help trying to make a hole bigger
Round surface chamfer
Curviloft surface of 2 arcs in 2 different planes
Trouble Subtracting Solids
About time to fix the "Radius is too small or number of segments is too large for given angle."?
Small Things
Sphere drawing problem - Mac mini M2
Adjustable sliding butstock mount
Need help with a curved shape
Intersecting a cylinder and a rectangle?
Intersect Faces Issue
Creating a Compound Radius
Exact measurements in mm
Problem with follow me
How to make a cylinder have rounded sides
Creating solid groups using 'Follow me'
"Follow me" leaves a random hole in my model
Pulling sphere out of a solid piece
Drape tool lines are not correct
Round corner doesnt work correctly
Subtract a screw from a box
Sketchup thinks my model is broken after scaling down
Getting dimensions in decimal instead of fractional
Joining two complex (rounded) objects?
Intersect gaps with curved slope cut out
3D Print Scale & SVG or EPS
Follow me tool and merging lines
Drawing failure, will not align properly and form surface
Using Trim results in non solid group
Around the round edge
Optimization of drawing in Sketchup Maker 2017 PL
Intersection trouble
Number of Segments too large for given angle and radius
Making bumps on object
Saving a model loses surface edges
Scan a custom molding profile into sketchup
Keurig + Nespresso Adapter Trouble
Newbie Qustion hollow dome
Slicing a model
Follow me tool
Follow me tool
How can I create a rounded top for this elbow?
New, Evaluating Sketchup Pro, Bug with Circle Tool Selection, Stability?
Making 3D text printable. Problem to make outer shell
Problems with subtracting solids
Having a volume filled and not empty
SU not responding on dream machine
Using line tool or rectangle tool to create surfaces to push/pull
Why are some of these components solid components and others not?
Building a car
Make 2017 - Odd Follow-me Issue
Is there a plugin which will give a x100/x0.01 scale button on the toolbar
[SOLVED] Merge faces and edges in shown example
Why is it not solid
Rounded edges for wood knob
Place shaft into hole
What’s up with SketchUp Make?
Disable Validity Check
Woodturning - Spindle Drawing
Making a complex taper?
Modeling Problem When I make a Bolt (stud bolt)
Box with rounded corners (inside and out)
Outer shell issue combining two solids
Corners when extruding along path
Scaling issues. Meters to MM
The elusive clothes hanger
How to draw a sphere for 2023 online
Sketchy solid subtraction
Dave Method Questions
Drawing spheres
Can anyone tell me why this happens in FollowMe, and how to fix it?
Kitchen Pulls
How do I create a torus-segment?
Spheres - can't make 'em
Export .dxf files to Cut Files
Miter Extrusion
How To Model Turn Down Edge
Help with threaded parts
Trouble with Solids Subtract Tool
Follow-me leaves gaps in surface or clobbers unrelated geometry
Why Extra Space Around Component?
Follow me creating partial path
Why do tops of my hemispheres and spheres get chopped off?
Follow me and the elusive clover
Drawing very small objects
How should I make a relief of my logo on an uneven surface?
3D Solids for Beginners
Intersecting 2 curved surfaces
Follow Me tool fails (when modeling at tiny scale)
Follow Me style Dome deleting itself
Help Needed to Round Off Edges
Problems with the Follow Me tool
Why are the vertices of the faces not moved with transformation? Is there any way around this?
Why won't Follow Me work here?
Surface border problem
Subtracting a solid changes the surface skin made by Curviloft
Having issue Intersecting Faces with complex curves
Shop vs. mm spheres, I give up
Follow me tool issue
Extruded Chassis Design
Subtract tool is breaking second component after subtracting
Follow Me Trouble - Extrusion Inconsistent
What dimension do people use? 1m vs 1mm for micro models
Making a stopped roundover
Follow me not following path
Follow Me Taking Breaks!
Follow Me not following all of path
Sketchup solid subtraction subtracts an unwanted piece of plane
Follow me tool not working properly?
Shape issue after Subtracting
Can I easily adapt the model size
Easier way to notch component
How to create a curved face
Small Details
Scale Tool Question too
Extrude along path with start and end point/shape?
Can't draw a dice, with rounded corners
Legitimate Sketchup glitch?
Follow Me Tool and Solid Inspector
Outer edge profiles in rail and stile doors
Can't unhide hidden geometry
Newbie - problems cutting holes through "followed" shape
Holes appearing randomly
SketchUp Doesn't Consider Component a Solid
Drape doesn't work at all
Can some one help me with this simple model?
Having severe difficulties with intersect feature
How to morph a shoulder strap from straight into half circle?
Round groove for o-ring on tube surface
Follow me function, There's a part missing
Follow me, along a curved surface
Doing threads in a thru hole on a curved surface
Taking slice from solid group ends up with non solid
Curved Solid subtract problem
How to Create a Solid of Revolution?
STL fails to slice properly
Error when trying to create rounded edge
How to fix uneven surface that comes from manually added line?
Blending radius in a shallow blind hole
Cut Geometry with a Solid Form
Minimum sphere size
Dealing With Scaling for 3D Printed Parts
Difficulty using push/pull on first project
Subtracting solid helix thread from cylinder
Arc segments for small models?!?!
Change amount of sections in arc/circle
SketchUp, but when you're just not into houses
Trouble splitting a solid with small edges
Trim gives strange results
3ds Max/vray importing into Sketchup
Follow Me doing strange things
Affichage des arrêtes manquante
Create a partial cove profile
Add a radius to the top of a cylinder
Problem with rounding edges
Not sure how to make this object (magsafe holder for car)
How to add a small weld line to two pipes / round corner plugin or alternative plugin
Add curved corners to tray
Cannot draw arch line
Follow Me Tool drops some details from profile
Issue with follow-me tool and missing surfaces
So I want to make this wavy can but I ran into a problem
Encountering issues with the Follow Me tool on SKP Pro 24
How would I correct these hard lines and make a smooth arch?
FOLLOW ME produces strange result
Disable the line warping/auto-un-correcting thing?
How to scale objects up and down accurately
Cannot Zoom right
Brail 2 font for SketchUp to provide accessibility media
Having Trouble with Follow Me
Using the follow me tool to make a cylinder shaped object
Follow me Fail
Fill-in a semi-circular rectangle
Subtract writing generated by 3D-Type from a pipe wall gets all messy
Segments of a circle or arc
Curved sides losing face
Revisit chamfer or bevel with follow me
How to draw a metric thread into a shaft
