Box
April 26, 2018, 2:35am
10
This may be just that you are using the wrong method for this specific shape.
See in the gif
First button produces that error last button makes the surface.
1 3/8" is pretty small, you should have a look here.
The Dave Method is the clever use of components popularized by @DaveR to avoid the tiny face issue.
Sketchup fails to form faces when edge segments get down around the 1/1000" mark. However, tiny faces can exist so the workaround has generally been to scale up your geometry, edit it, then scale back down.
This works, but can lead to some issues.
The Dave Method leverages the power of components to make life easier.
The basic concept is, you start with a component set at the size you want, t…
