Hi
For some reason I can’t make a face out of a few curved lines?
So I f I have a small arc then copy it and join the two arcs with straight lines it should form a face, but it does not. Any ideas?
Hi
You need to ensure that all of the entities are planar in order to form a face. One way to do this is to first model a rectangle and then place your arcs and the connecting edges directly on top of the rectangle. Once this is done in the same plane, the faces should be formed and you erase the rectangle.
ok thanks.
Yes this is correct.
So how do you create all the faves to the curve?
ok got it. Thanks again. appreciate it.
