Encountering issues with the Follow Me tool on SKP Pro 24
Hello, I am having problem with the follow me tool. The dimensions on this model are about. 1-1/2" by 3/4"D.
Please see the screen recording.
Too small, look here.
Thanks! Makes sense. I wish it worked with small arches.
Anyhow, I just. mimicked the look.
It DOES work with small arches, IF you follow @Box advice!
Read the topic in the link he gave you…
Scaling down? I don’t see that as straightforward workaround. So, no, it does not work as intended.
Who said anything about scaling down? With the “Dave method” there is no scaling down involved.
SketchUp has limitations for creating very tiny faces. It was not designed for modeling tiny objects such as your knobs. The faces can be created at a larger size and exist smaller. Using the Dave Method only requires making a copy of the component and scaling the copy up before running Follow Me or doing other things that would create the tiny faces. After completing the Follow Me step, exit editing mode and delete the giant copy of the component. Zoom back to the original copy and the geometry will be there.
Follow Me is working as intended. SketchUp is doing what it was designed to do.
All I can say is, good luck with the next software you choose. This one isn’t for you.
It does not.
Wrong answer. Wrong attitude…
I don’t understand why are you settling with less and not pushing the dev team to make SketchUp better?
Besides, I’ve invested way too much TIME and MONEY to listen to your recommendation and move on with another software…
Such a fantastic argument.
So you would rather wait some years or forever before you model your doorknob instead of just taking the advice you have been given and get on with it. The limit to SketchUp’s face creating capability is somewhere about 1 mm and it has been known and nagged about for decades. I would guess at this time in history it is take it or leave it.
SketchUp is a face modeller. I understand fixing the problem would require a complete rewrite of the application, using a solids or NURBS core. My prediction is that it won’t happen. Jewellers use other software. SketchUp was from the start geared towards architecture. That’s why you cannot model a virus or the solar system to full scale with it.
It’s well known and often complained about…
But to avoid the tiny edges issue would require the entire SketchUp program’s geometry engine to be rewritten to stop its internal tolerance of 1/1000" causing these issues.
SketchUp regards any two points closer than its tolerance to be coincident, so the tiny <1/1000" edge is not made and its related faces are not made.
This isn’t a problem when real world sized objects like buildings, doors and windows are modelled.
With the advent of 3d-printing and very detailed work becoming more popular the ‘scaling’ fix was devised. Dave codified this in a simple solution.
Make your object in a component.
Copy it to one side and use scale to blow-up that copy [say by 1000].
Now edit it and do your operations inside that copy.
Because it’s not going to have the tiny edges issue it should work.
Exit the edit.
When you edit a component instance any of its siblings are similarly changed.
If you look at the original it will also be OK and modified.
Delete the temporary blow-up copy.
The original sized copy keeps its changes.
Tiny geometry can exist in SketchUp, but it cannot be created.
Your failure is not a ‘bug’ it’s a limitation of the software.
You’ve been given a workaround which takes seconds to do, but prefer to spend unproductive hours complaining about something that’s not going to change any time soon.
Even then you could complain that say you model of a real sized atom wasn’t working because the new tolerance was too coarse.
No one is defending SketchUp’s foibles, or attacking you personally - although you have not been so generous to members sincerely trying to help you.
You are in danger of a ban for your rudeness and ‘ungentelmanly-conduct’ = @TheOnlyAaron
You said that 1mm was too small for SketchUp to work properly.
In my problematic model, the line is 6mm long.
But you see, that’s not my case… my line is 1/4".
You have failed to understand that all of the related geometry, like the circle, might contain tiny edges [within the tolerance] but the follow-me created geometry might then be even smaller and fail.
The solution offered works.
Use it, or don’t model tiny geometry, or find another software.
None of this seemingly endless diatribe gets anyone anywhere fast the hard way !
We can only guess, but you have to understand that in a 3d environment 6mm is only one dimension. The endpoints of the 6mm edge could well be within .002 of another edge.
I did check the “template” circle as well and each line of the circle is 1/16". So this could’ve been the problem?
Jeez… this is getting more and more complicated lol
Anyhow, thanks for your temporary solution. SketchUp should use it as a suggestion when people use follow me tool.
