So I want to make this wavy can but I ran into a problem
The first picture is the 2d one, but when I tried to use follow me, it wouldn’t work (second picture)
hello, what is the approx size of your model ? try to scale it up x100 before using follow me tool.
Sketchup will fail building really tiny faces, especially with those curves that would imply creating plenty of them
Yey, scale it up or use The Dave Method:
the height of the little circle is 4 mm and the total height is 130 mm
there you are, too small !
IT WORKEDDD TYSMMMMM, but if I scale it down will it dissapear?
nope !
Thank you paull I was looking for solution for three hours now and you saved me
If you follow @dezmo’s second piece of advice you won’t have to scale down after Follow Me.
Also, before running Follow Me, delete the face of the circle so the bottom of the “wavy” shape is filled after Follow Me completes. Or place the circle so it is not touching the profile shape.
