Sketchup Pro 2023 Custom Trays Have Portions Blacked Out
Windows 11 Pro 22H2 Build 22623.1325
Intel(R) Core™ i9-10900K CPU @ 3.70GHz, 3696 Mhz, 10 Core(s), 20 Logical Processor(s)
64GB Ram
Sketchup Pro, Version 2023.0.367 64-bit
Installed new version today,
Created 3 Trays, T1, T2, T3
T1 contains Components
T2 contains Entity Info, Tags, Scenes
T3 contains Materials, Styles, Soften Edges
When I open SU Pro:
The T1/Components window is blackened out
The T3/Materials and /Styles windows are blackened out.
I have to close and reopen the trays for them to display properly.
It happens every time I open SU Pro 2023.
I disabled every plugin and restarted - no impact.
I deleted the trays and recreated - no impact.
I renamed the global and local preferences JSON files and rebuilt the toolbars and trays - no impact.
Here’s a screenshot:
Any input toward resolving this is appreciated!
Have no similar issues in SU Pro 2022.
Seems you are not alone… :frowning:
Well, that would suggest it’s them and not us… I submitted a ticket to SU, we’ll see how quickly they respond.
There’s a way to make this a bit more convenient as a workaround.
Merge all your trays into one like so:
It’s just a matter of dragging all the trays together and anchor them on either side:
You can then set this tray on your secondary monitor. When Sketchup loads, just slightly resize the tray and it’ll start working again. It’s not much, but it’s a workaround.
Just tried this on my system and all was well.
Thanks for the responses - SU has responded to my bug review request and they’re working on it. Will advise of any progress or suggestions they make.
I submitted a bug report and it has been escalated up a tier. SU recognizes it’s a bug.
Resizing the tray seems the easiest work around for now. I wrote an AutoHotKey script that positions my trays where I want them and added a line of code for each tray to resize it slightly and size it back again. It resolves the black screen issue and an issue where clicking on a component isn’t updating the model info dialog. With 3 monitors, I can easily move the trays with the hotkey to the left, middle or right monitor and the resizing code I added seems to get the trays back in proper working order.
I’m having the same problem, except that my tray panes aren’t blacked out; they simply retain their initial values. I posted about it in the thread that dezno mentioned above.
Would you mind sharing your AutoHotKey script?
Bret Sutton
@OldCoot - The AHK script is below. Take careful note of the comments. A lot of this is hard coded to work with my setup, so you may need to make adjustments. Use at your own risk.
; AlignTrays - Align Trays
; I have to run in administrator mode for this to work with Sketchup 2023
; This is set up for 3 monitors.
; My display resolution is 2560x1440
; You may have to adjust defW/defH variables below for your screen
; This script also assumes the center display is the primary monitor,
; with the left monitor having negative coordinates, the center monitor starting at 0, 0,
; and the right monitor starting at the display width coordinate.
#NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases.
#Warn ; Enable warnings to assist with detecting common errors.
#Singleinstance force
;SendMode Input ; Recommended for new scripts due to its superior speed and reliability.
;SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory.
;--------------CRITICAL INFO-------------------
;I’m working with the following customized SketchUp trays:
;T1 (SU Tray 1)
;T2 (SU Tray 2)
;T3 (SU Tray 3)
;Model Info (SU model info)
;Profile Dialog (profile builder dialog)
;set AHK definitions
;Use Alt+F9 to align left, Alt+F10 to align center, Alt+F11 to align right
!F9::AlignTrays(1)
!F10::AlignTrays(2)
!F11::AlignTrays(3)
AlignTrays(mon)
; Get the system settings for available monitor space
SysGet, m, Monitor, %mon%
defW := 447 ; default width of the trays, adjust as needed to your monitor resolution
defT := 30 ; This can be set to zero, but I need an offset at the top because I have WinStep loaded and it takes up some top space.
defH := 1100 ; default height of trays, adjust to your monitor resolution
if (mon = 1)
x1 := (mRight - defW)
else
x1 := (mLeft)
; set the the position of T1, everything else aligns with it.
; the +10 was added here to resize the window to work around a SketchUp bug.
; the next line can be removed once SU fixes the bug
WinMove, T1, %x1%, %defT%, defW+10, 1100 ; remove when bug is fixed
WinMove, T1, %x1%, %defT%, defW, 1100
WinGetPos, x, y, w, h, T1
; some adjustments to get coordinates to align.
; the sketchup trays don’t report window sizing the same as other windows, so had to adjust
if (mon = 1)
x1 := x - defW - 1
else
x1 := x + defW + 1
y := defT + 1
; move and size tray 2 equal to tray 1
WinMove, T2, x1, y, defW+10, h ; remove when bug is fixed
WinMove, T2, x1, y, defW, h
if (mon = 1)
x1 := x1 - (defW - 1)
else
x1 := x1 + (defW + 1)
; move and size tray 3 equal to 1 and 2
WinMove, T3, x1, y, defW+10, h ; remove when bug is fixed
WinMove, T3, x1, y, defW, h
; move model info to new coordinates
if (mon = 1)
WinGetPos, x, y, w, h, Model Info
x1 := (x1 - w + 6)
else
WinGetPos, x, y, w, h, T3
x1 := (x1 + w - 6)
y := defT - 1
WinMove, Model Info, x1, defT
if WinExist(“Profile Dialog”)
; adjust coordinates for profile builder
y := h + 24
h := defH - h + 12
; move profile builder dialog under model info
WinMove, Profile Dialog, x, y, w, h
And it seems that choosing a layer in ENTITY INFO by pressing the first letter doesn’t work any more too…
For example… If I select a group and roll out the tag selection menu in Entity Info and then press “P” to quickly select a “People layer” sKetchup will push-pull instead of scrolling down to layers starting from P. I guess this is related to trays not refreshing too…
I see a fix to another issue that could have caused this. I added a note to that fix, to point out that it may have broken the Entity Info tag menu selection.
2023 is officially first relies that makes me want to go to previous version… I’m with sKetchup since sK-7. Is it really an official relies or I downloaded some beta testing version? It says 23.0.367.
It doesn’t have some extra new things that I would be in need of and broke at least 3 that I use and can name:
-Trays
-Entity info Tag menu
-Drape Tool…
