Model has disappeared
I had the same problem can you help me as well? I believe the bad components are the coffee mugs, man with backpack and blood splatter
CrimeScene.skp (2.3 MB)
solved here
(posting this so people won’t try to solve it again here)
Hello Dave I hope you could read this, I also have the same problems where my sketchup created models disappeared and I humbly seek your help to recover the file so that I can still use it. Attached here is the link for the file itself. SITE DEV_FINAL.skp - Google Drive
Hello ateliernab I hope you could read this as well, I also have the same problems where my sketchup created models disappeared and I humbly seek your help to recover the file so that I can still use it. Attached here is the link for the file itself. I’m too desperate to fix the files :< SITE DEV_FINAL.skp - Google Drive
already solved here
Thank you as well, @ateliernab!
Hi, anyone could help me? Couldn’t find and zoom in to my model as well. I tried opening the file in a high settings pc, problem persist. https://www.dropbox.com/scl/fi/k4272ani046zrtqen5s0n/Parklane-Hotel.skp?rlkey=eo1uqh4sdsc6ciwebfna4kfcj&dl=0
Your problem was 592 texts. I deleted them (they was very big…) and zoomed extend.
Here is the model purged
Parklane Hotel_v2.skp (15.0 MB)
Wow I was so scared my boss was asking for it. Thank you very much @rtches, I thought it couldn’t be save anymore. Great helps!
hi, im also having a problem about that, can you help me out?
SVSBF.skp (5.3 MB)
hi! I’m also having the same problem, can you help me out?
SVSBF.skp (5.3 MB)
hi! im also having the same problem, can you help me out?
SVSBF.skp (5.3 MB)
@Tamiko ,
There’s no need to post the same message 3 times. We all can see all messages, regarding who you are replying to…
Please keep the forum tidy…
i’m sorry
You have multiple copies of a group spread out at a huge distance.
Use ctrl+a to select all, then shift select to deselect what is at the origin, try Zoom Extents, if it doesn’t work repeat until it does.
As you see here it took 3 goes to get there.
GIF 14-12-2024 11-23-39 PM
guys im having the same problem how to do this T_T FINAL CE MODEL.skp - Google Drive
Hi Hit Ctrl+A to select everything in the model and then use Zoom Selection and the model appeared. I also did my usual cleanup procedure. First I fixed incorrect tag usage.
Then I purged unused stuff from the file. There’s really no need to be hoarding all those components and materials.
Then I looked at the remaining materials and reduced the size of the excessively large ones.
That resulted in about 82% file size reduction. More could be done such as removing the page borders and other unneded geometry from the CAD import.
I’ll come back with the link once I’ve uploaded.
Edit to add link: Dropbox
hello, my model has also disappeared… please help.
W can’t do anything until you share the model here. If less than 16MB just drag it onto the forum reply window. If larger, load it to a sharing site, make it public accessible, and provide the link here.
Thank you- this is my first time using this forum. Really hoping you can help
beasley courtyard.skp (4.0 MB)
