Layout to PDF font issues
Downloaded latest version - bullets still turn to boxes and letters in list vary in size.
Here’s how it looks in layout:
Hi all, we had made stability improvements with files containing bullets and tabbed text will now export with this release, but we were unable to fix these remaining issues with export to pdf. Unfortunately, the only current workaround for this is to print to pdf or to not use the list feature with text.
Sorry for the inconvenience, we are working on this fix.
Trent
Trent,
You seem to imply that the problem of LayOut corrupting bullets when exporting to PDF has been fixed:
“… we had made stability improvements with files containing bullets and tabbed text will now export with this release …”
But as far as I can tell there is no change … LayOut is still not exporting bullets to PDF properly.
A simple LayOut test file and the resultant export to PDF are both attached:
210621A Bullet Test.layout (1.9 MB)
210707A Bullet Test Export.pdf (1.6 MB)
And yes, I am running the latest release: LayOut 2021 Version 21.1.299 64-bit
Regards,
E. Godsey
GTA Design
Hello, I have the same problem since yesterday. Tried everything, nothing helped. Strangely, exporting to PDF just worked well. JStockCo’s comment got me on the right track. Fixed it by removing all TABS in text and creating long spaces with spacebar. Problem solved, but of course it’s not the way, but I am glad to know the problem is in the software and not in one of my actions. Hopefully it will be resolved soon in the upcoming updates. JStockCo: thanks for the tip :slight_smile:
Hi egodsey, we had a crash that could occur with files containing bullets and that has been fixed but we were not able to get the issue discussed here fixed with this release. So no, exporting them does not work only printing to PDF does not show the issue.
Trent
I am now having this issue.
Hi ingersoll3design, would you be able to share that file with me?
Trent
I managed to manipulate this enough to work here is a version that is a problem. It seems that something around where the diameter symbol should be is a problem. It would be right after the 3/16". I am not sure why the symbol disappeared or is an issue.
8’ CHEW GUARD.layout (475.7 KB)
Ok. Thank you for the clarification. Meanwhile, I am with diki … it would be nice to get this resolved.
I’m encountering the same issue with my existing documentation. It is using a completely different font family than those listed here. Unfortunately my workflow has become rather reliant on having the option to print to a certain quality level afforded me during export to .pdf so I’m less inclined to use windows .pdf as that turns out completely unresponsive and/or creates a 0 kb file and my print to Nitro version creates a completely uncompressed file. I have 100’s of documents that unfortunately get tweaked and re-exported here and there and this is about to rock my world as during the most recent I’ve seen this result.
Left side is the layout file and the right is it exported to .pdf result. Those elements were literally duplicated so they are the same font and settings all around. No bueno =(
Make sure the file isn’t already open when trying to export via overwriting. I get that message a lot because for some reason my brain does a better job redlining my own work after an export in a .pdf editor then it does within layout (yep I’m coo coo) so I usually spot mistakes, fix em, and try to overwrite without first closing it down.
This was not related to having the document already open but I have had that from time time. We also tried this on another machine with the same problem. I did manage like I said to work around it but it is curious to have this issue to start with.
Any updates to this issue?
Hi all, the update on this issue is that we have identified the problem and we are actively working on a fix for this. We hope to have it resolved soon.
Trent
That is fantastic to hear, thank you.
Is this issue related?
Anything outside a text frame gets eliminated from the PDF, despite it being visible in LO.
And this one?
Okay… so every single one of my layout files have now blown up and default to Arial. Many weeks of laying out pages across 100’s of documents is gone, have absolutely no idea why that would happen short of my deliberately uninstalling fonts in my windows system font folder which I certainly did not do. Layout no longer even finds that font family I was using in the fonts list despite my triple checking that it is installed on my system. I’m probably going to get fired thanks to this for not using an adobe product.
Attached image of my installed font family on left and Layout asking me to find the missing font and replace it on the right. :worried:
Is it an issue between ttf and oft fonts ?
Perhaps Layout needs the ttf installing ?
If the computer you are currently using doesn’t have that font-type [ttf] installed [available and used in the original Layout document], then Layout wants to substitute another font that is available ???
What file-type is ‘Gotham’ ? If it’s otf try installing and using the correct ttf ???
I have both versions of the font installed so layout has its choice but finds neither. All other app have no issue with finding the font whether Adobe or windows notepad. Definitely a layout specific issue.
