I keep getting the following error when trying to export a PDF from LayOut. I’ve been exporting to PDF this exact same way previously without any issues. File > Export>PDF. When I printed to PDF instead I ended up with a 47MB file which was way to large to email. (the LO file is only 29MB) I exported to PDF from this same file last week and the PDF was 5MB.
I see that message when I’ve exported a PDF from the file and it’s open in Acrobat and I try to export from LO again after I’ve made a change to the file. Closing Acrobat takes care of it.
Ik heb het zelfde probleem bij het exporteren van Lay Out naar PDF krijg ik de zelfde tekst als hierboven.
Ik heb nu Sketch Up en lay out 2020, maar nog steds het zelfde probleem. A4 en A3 formaat kan ik nog oplossen door af te drukken naar PDF, maar grotere formaten lukt mij niet. Wie kan mij helpen dit op te lossen?
We had a customer contact use with this same issue, only he had isolated what it was in the document that caused the error. I made another file that only has that element in it, and was able to add a 6kb sample file to the existing bug report.
I don’t even know what the element is, it’s a bit like hidden geometry in SketchUp. Here is my example file, look at it, notice how you see nothing, try exporting to see the error, then do a Select All. When you do that you will see the object. What is it?
@colin , we had this same problem a while ago. Your example file contains a corrupted Linear Dimension. Specifically, many of the numerical values defining the linear dimension are NANs (That is Not-A-Number). I can only guess how this corruption is happening, but wont.
Here’s some of the data from inside the layout file.
I just received this error for the first time. Saved down to 2019 Layout and it worked but I had never experienced this prior to today and it was not due to having the file already open. Let me know if you need my files to help fix the issue. Thank you
I assume this means you are using SketchUp/LayOut 2020. Correct? Out of curiosity, when you installed SketchUp 2020 did you right click on the downloaded installer and select Run as administrator from the context menu?
Correct installation of SketchUp/LayOut on Windows 10 requires that you right click on the downloaded installer and select Run as administrator. Before doing anything else, I would suggest that you close SketchUp and LayOut. Then go to the downloaded installer file, right click on it and choose Run as administrator. When the options appear, choose Repair. After SketchUp and LayOut are correctly installed, try the export again and see if there’s a change.
I think I had already set my permissions to open as admin by default on executables as I have the windows admin icon in the bottom right of the install icon. Nevertheless I did as you suggested and opened the installation as admin and repaired and tested the export to PDF again. Unfortunately the issue still persists and it simply gives me an error message stating that there was a problem exporting to the file. I appreciate the help in suggestions though !
I just upgraded to SketchUp 21.1.279 and when I went to export to PDF, I get different font size if I have used the TAB button to make an indent. This is what it looks like in Layout:
And here is what it looks like in PDF:
If I “Untab” it, it looks like it ought to in PDF:
I’ve never seen that before but it’s doing it for me with your file. I copied the text into an RTF file which I inserted into your file and those indented lines show with larger font there, too. Using spaces to create the indents works fine, though. The one on the left is my rtf file using spaces.
Hopefully Adam will have something to report. In the meantime I guess there’s an option for you to avoid it. You could also use a table created in LO or a spreadsheet. A spreadsheet might be a good option for this because you can have a .xlsx file as a template that you can easily edit and update as needed for each project.
Here I made a quick example from your text. This is in a spreadsheet inserted into LO. the spreadsheet can be edited to change the colors and revise the misc. details without affecting the formatting.
Thanks for reporting this problem. We did make a change to how LayOut exports PDFs which was aimed at fixing other issues in this thread. This size shift on indent may be an unintended consequence. We will take a closer look.
