Downside of resin printers is that they typically have a smaller printvolume.
That would mean you have to cut the model in even more pieces..
From a post about ‘woodturning basket illusion’
A one-minute presentation of an extension for SketchUp (Make 2017, SU2026) that offers the possibility to divide an irregular 2D surface into equal parts.
I asked Google Gemini to create this extension for me and after the second attempt a code worked. Two or three more discussions and tests followed, resulting in a code that works very quickly (2 seconds) to divide into 3-6 equal and accurate surfaces (one or two decimal places).
Premieres: 2025-12-01T07:00:00Z (Eastern European Time) UTC/GMT +2
Premieres is just for testing this YouTube feature.
Divide Area Equal by ms
and this, my son, is why none of the plots in our street has a single right angle…
neat ! ![]()
Hi Eric (@eric-s), and thanks for the new video!
In Gemini, I used the image from the video and a text explaining that it was necessary to fill in the two sides taking into account the existing landscape, plus adding a wooden house on the left and some boulders and grass on the right, and very quickly this image was generated.
You had an inspired idea for the video. ![]()
Pretty spooky and cool what it can do now huh?! Nice work Mihai.
It’s interesting.
The other day there was a discussion in the forum about how a rendering was created and I tested it to see how it changes the original picture depending on what I ask it to do (add thatched roof and bougainvillea on the walls).
Then yesterday I tested (including text generation) Aaron’s fireplace (@TheOnlyAaron), both in AI Render (SketchUp) and in Gemini.
A two-minutes presentation of an extension - 'C2C lines 3p’ - for SketchUp (Make 2017, SU2022, SU2026) that offers the possibility to draw a centerline based on successive triple point selections inside a 3D shape.
The extension is still in testing, unpublished.
I asked Google Gemini to create this extension for me and after two attempts the code worked.
A two-minutes presentation of an extension - 'C2C Line 2p’ - for SketchUp (Make 2017, SU2022, SU2026) that offers the possibility to draw a centerline based on successive two point selections on a 3D shape.
I asked Google Gemini to create this extension for me and from the first try the code I created worked as I wanted.
wait, if we start publishing plugins (even AI made ones), do we count as devs ? can we go to devcamp in england ?
only good use of AI I have seen suggested here!
This might work well with MS Divide Area, or a modification of it, too.
And I also hope I don’t upset @dezmo too much (with this AI), who created a thread (Dezmo’s ex*-tension*) where I had the opportunity to ask him to create an extension, but if this option appeared with AI, I wanted to stop burdening him with a lot of extension requests
Dezmo, again, thank you very much for the extensions you created!
And of course, JamesD (@3DxJFD) too! ![]()
Thank you!
I have a SketchUp Extension Review Checklist. It’s not complete but most of my reviewer comments and things I might miss are in it. I recommend you make one (file extension, .md) and keep it in your Plugins folder. As you go along you can add a RuboCop file too. Some of the offenses that crop up can be added to your Checklist. You’ll start to have a nice little basis of things to-do and not-do ![]()
