We’ll update this thread periodically with information about the bits and bobs that are included in each new release of SketchUp for iPad.
June 1, 2026 – Here’s what’s new in SketchUp for iPad v8.2.1 (3289)
Resolved user reported issues with the newly redesigned measurements box, and fixed several bugs around app stability.
Bug Fixes
- Removed Apple Pencil scribble inputs in the measurements box after it caused issues selecting and editing values. This returns measurement editing to its previous behavior with the Apple Pencil.
- Resolved a bug that prevented semicolons from being recognized properly in the measurements box for regions using semicolon numerical separators
- Resolved a bug that prevented commas from being recognized properly in the measurements box for regions using commas as decimal separators
- Fixed a crash affecting models with unused materials that occurred after saving. While saves were successful, subsequent crashes could happen at any time.
We hope these fixes help improve your modeling experience! Your feedback is invaluable, so please keep sharing your thoughts and suggestions.
May 19, 2026 – Here’s what’s new in SketchUp for iPad v8.2.0 (3285)
Model easier on your iPad with a redesigned, touch-friendly Measurements Box, improved DWG/DXF imports (say goodbye to post-import cleanup!), and collaboration so smooth you can share files with a single email. We also squashed bugs so your keyboard shortcuts and Live Components play nicely!
General Improvements
- Redesigned Measurements Box: Larger, easier to read, and touch-accessible. It remains persistent when undocked and responds to pencil input.
- Tape Measure: New “Toggle guidepoints” sub-button allows you to switch between guide lines and points creation.
- Enhanced support for hardware keyboards, more reliable shortcuts usage.
- AI Render: Faster gallery thumbnail loading and a new refresh button for better single-image workflows.
DWG/DXF Improvements
Enhanced import/export fidelity and efficiency. This includes new import options, hatch import support, and preserving section planes and curves on export.
- Import Layers as Groups option: creates groups matching the DWG’s layer structure. Imported layers retain their Tags, but grouped geometry now allows for better visibility control.
- Import Linework Flattened option: sets imported geometry’s Z-value to 0, reducing post-import cleanup for 2D CAD to 3D conversion.
- DWG Hatch Support: Imported solid hatches become faces. Non-solid hatches become edges.
- Exporting 3D Sections: SketchUp section planes are preserved in 3D exports for use in AutoCAD.
- Polylines: Now import as welded lines.
- Components: Improved naming to reduce duplicate data.
Collaboration Improvements
- Easier model sharing: First time collaborators can now join shared files via a single email invite, removing the need for manually adding contacts.
- Invite Management: View pending invites directly in the sharing dialog.
- “Share a Link” is back in the Recent Files and Trimble Connect overflow menus.
- Multi-Editor Management: New warnings and file closing is enforced to maintain data consistency when another editor opens a file that you are in (possible with Trimble Connect projects when you give teammates access)
Bug Fixes
- Fixed keyboard shortcut disconnects and cursor navigation in text boxes.
- Fixed Move, Rotate, Flip, and Scale tool issues with Live Components.
- Improved Measurements Box label display and shortcut consistency.
We’re excited to hear what you have to say about these updates! Please let us know what is, (or isn’t) working for you by sharing your thoughts here on the forum.
April 30, 2026 – Here’s what’s new in SketchUp for iPad v8.1.2 (2276)
Bug Fixes
- Fixed an issue that prevented a user from downloading a generated object from the SketchUp Assistant.
- Segments Tool: Fixed an issue where the “Increase Segments” button was not functioning.
- Comment Threads: Fixed an issue in the iPad Viewer where new comment threads from the editor were occasionally not fetched.
- Viewer Stability: Fixed a bug where an autosave could cause a real-time viewing session break.
- Comment Images: Resolved an issue where images attached to comments would appear as gray boxes on iPad.
February 23rd, 2026 - Here’s what’s new in SketchUp for iPad v8.1.1 (2257)
In this update, we’ve squashed some pesky bugs and fine-tuned the interface so you can focus on what matters: creating.
SketchUp now requires iOS 18 or later: By focusing on the latest operating systems we deliver a faster, more secure experience for everyone.
Live Components
Scaling: Scale enabled Live Components can now be dynamically scaled in SketchUp using the native Scale tool, offering greater placement flexibility.
Painting: Use the Paint Bucket to paint Live Components. This updated workflow now includes better texture mapping, and painting while a Live Component is selected.
Collaboration
If you’re exploring a link-shared model, you can now toggle panel settings to see how different styles or tags look. To keep the “source of truth” safe, these panels return to a read-only state the moment the Editor joins the Collaboration session.
Bug Fixes
- Arc & Pie Tool Stability: Entering large values while drawing with the Pie Arc tool will no longer cause the app to crash.
- Angle Snapping Fix: A localization bug where Angle Snapping reverted to 1° in non-English languages has been fixed for our international users.
- We addressed an uncommon error when opening Trimble Connect files from the Home screen after a “Save As” operation that would report the file as “Not found”.
- The right-side buttons in Portrait mode are now stable and won’t shift when the context menu appears, ensuring a predictable workspace.
- Fixed an issue causing the Share bar to drift off-screen when opening the first model after launch.
- We fixed a visual glitch in the Outliner after clearing a search that caused entries to stack on each other in a jumble.
- Fixed a bug that prevented a user’s name from updating correctly under the profile image in the upper right of the home screen
- Fixed a bug that caused crashing when docking toolbars in the editor
- Resolved an issue where double-tapping with the Apple Pencil failed to apply corner inferences in the 2-point arc tool while in “Click-Move-Click” mode.
- Fixed top crash bug that caused the app to crash when attempting to add a comment to a newly shared collaboration file
Every great design starts with a conversation, and we want to keep ours going, so please keep sharing your thoughts and suggestions here on the forum.
December 16th, 2025 - Here’s what’s new in SketchUp for iPad v8.1.0 (2227)
Collaboration in SketchUp
Skip sending a screenshot and start sharing in 3D! You can now invite colleagues or clients right into the model with you. Viewers can measure, comment, and watch your design magic happen in real time. Whether they’re on the Web, Desktop, or iPad, they’re in the loop. Dive in: https://help.sketchup.com/en/connect-and-collaborate
Comments
Introducing the new Comment tool, your personal 3D highlighter for communicating with precision! Just activate the Comment tool from the toolbar, context menu, or Collaboration Bar, then tap your model where you want to place your thought. The Comments Panel instantly opens when leaving a comment, letting you review threads, add replies, and hide comment markers for a clean viewport. Consider this your digital sticky note system, but way more organized. Learn more here: https://help.sketchup.com/en/commenting-model
Real Time Viewing and Camera Controls
By default, your viewers see your model updates as they happen—like a screenshare, but with way more precision. Changes you make will appear for everyone, and viewers can even see the tool you are using to make changes if cursors are visible. Tools that viewers are using, like the Tape Measure, Pan, or Rotate, are also visible to everyone.
Once all your stakeholders are in a model together, you’ll probably want a way to reliably guide them around, right? Just tap your avatar in the Collaboration Bar and everyone’s view will sync to yours—instant design presentation mode! Conversely, want to follow another viewer? Tap their avatar and enjoy the ride! For the full scoop on the real-time experience, check out: https://help.sketchup.com/en/real-time-viewing
Bug fixes
- Fixed a bug that caused a crash when attemtping to use the scale tool on a live component
- Fixed a bug that caused the in-app avatar image to disappear when restarting the app
- Fixed an issue with the iPhone viewer that caused the lasso tool to display incorrectly on top of menus
We hope you love these new features and improvements as much as we do! Please share your feedback, concerns, and suggestions here on the forum. Happy collaborating!
December 9th, 2025 - Here’s what’s new in SketchUp for iPad v8.0.0 (2221)
AI powered tools
Get ready to level up your workflow with SketchUp AI, a new suite of services designed to be your creative sidekick in SketchUp! Look for the sparkly new icon in your home toolbar to launch these power-ups:
AI Render lets you generate stunning, presentation-ready renders of your model viewport with a single tap. Want full control? Dial in your perfect look with preset styles, custom prompts, and advanced settings. Plus, our powerful in-painting tools let you refine and perfect those tricky spots in your renders!
AI Assistant is your new go-to for smart design assistance! Help Assistant offers tailored, in-app guidance so you’re never stuck. Generate Object lets you conjure 3D objects (complete with PBR textures!) from just a text description or image. Your new creations download right into your model or can be found in a private 3D Warehouse collection!
AI Credits & Subscriptions
SketchUp AI features run on AI Credits. All our paid plans come with a monthly allowance, and if you’re a design superstar needing more juice, grab an AI add-on subscription for a much bigger monthly quota! Tap the AI toolbar icon anytime to check your balance!
Improvements
We’ve added a My Profile link under your user avatar on the home tab. It’s your quick path to managing your Trimble account — update your avatar, set personal preferences, and manage your passkeys.
Bug fixes
- Fixed an issue where the extra settings in the Create Component dialog were playing hide-and-seek. They’re back!
- New files created while in a Trimble Connect project now show up instantly.
- Fixed a bug that occasionally caused a crash when using the autoshape tool.
- Local file thumbnails will now update properly in your recent files list.
- You can now tap and view the same image in the AI Render gallery multiple times without issue.
- We fixed a bug that made duplicate versions of the same Trimble Connect file appear in your recent list.
- Fixed an AI Render bug: Reference images now correctly guide only the “No Style” preset, not all presets.
Dive in now to explore these exciting new AI-powered creative tools, plus bug fixes designed to power up your workflow!
November 5th, 2025 - Here’s what’s new in SketchUp for iPad v7.3.0 (2208)
Introducing AI Render
SketchUp Diffusion is now AI Render, and is more powerful than ever! It features new inpainting tools, additional style presets, and a completely redesigned user interface. These changes continue to expand and enhance SketchUp’s AI capabilities. GO subscriptions now come with dedicated monthly AI credits. Credits refill monthly, and you can monitor your usage via the credit balance menu in the upper-right while using AI Render.
File save improvements
We’ve made significant updates to how you save your files! A new navigation menu is now located on the left side of the home bar, gathering both new and existing options. While the save button remains easily accessible on the home menu bar, saving a file now gives you the option to select a save location and assign a name.
- Tap the file name to rename your file
- Tap the Save as button to save a copy of your file
- Tap home in the menu to return to the home page, as always
- Find Import and Export file options now under this menu
- App settings are also now under this menu
Model and Visualization Improvements
Ambient Occlusion face setting received two major improvements
- The Distance Multiplier slider when using AO on tiny or really large models.
- A color swatch control allows you to pick custom color for your shading.
Invert Roughness gets a similar setting to invert normal. Inverting roughness provides better control how smooth or rough you want a surface to be.
Scale grips now display through other geometry, so that you can always see and click them.
Rotation grips no longer appear when you’ve locked a rotation plane.
Scene Undo and Redo
You can now undo or redo scene updates. Undo and Redo work just like they do when editing other parts of your model and will also respect creating, renaming, and deleting actions.
Your input helps us continually improve SketchUp for iPad, so please keep sharing your thoughts here with us on the forum
October 22nd, 2025 - Here’s what’s new in SketchUp for iPad v7.2.1 (2197)
Here’s whats new in v7.2.1. Feature improvements and bug fixes!
Improvements
- Users can now clear locally cached Trimble Connect files from their device, similar to iCloud’s “remove download” option. The new “remove offline version” option is accessible via the overflow menu for Trimble Connect files in your recent files list.
- Enlarged the tap area for the measurement box to include the entire box, allowing you to more easily type measurements.
Bug fixes
- Fixed an issue where the measurements panel extended beyond the display when docked at the bottom of the screen
- Fixed a crash that occurred when downloading 3D Warehouse models and then exiting the app before saving.
- Fixed an issue where the rename command was absent from the overflow menu for files in the Trimble Connect Tab
- Fixed a bug that caused a user with a newly created TID to not be able to enter the free viewer mode.
September 23rd, 2025 - Here’s what’s new in SketchUp for iPad v7.2.0 (2192)
This release is packed with an exciting update to SketchUp Diffusion, check out all the details below!
New UI
Full-screen mode: Tap the Diffusion button and watch it go full-screen. No more refreshing—what you see is what you use to generate. Diffusion results now also show up full-screen in your viewport automatically and can be selected or deselected in the new Gallery panel.
Navigation: Freely navigate your model and adjust styles while in diffusion mode. Generated jobs now also remember where they were created, so rest assured that you can always return to a job’s camera location just by tapping it from the gallery.
Bottom toolbar
Jump right into prompting and generating with the new bottom toolbar and a new Autoprompt preset that will generate a detailed prompt for you. 1-click generation has never been easier! Take your images further with our new set of paint, erase, and sketch tools.
Prompt Tool: The original prompt tool is still here, with advanced settings now found by tapping the settings button next to the prompt button and preset selection from the top of the settings window. You can find advanced settings under the dropdown, settings like Prompt Influence, Respect Model Geometry, and Negative Prompt.
- Style Transfer: This exciting new setting can be found in the advanced settings of the “No Style” preset and lets you pick your own image as a style reference for the generated images. Want your Diffusion results to look like your hand-drawn sketches? Load a scan of your sketches as a reference and see the magic happen!
Image Tools
New in this release are a set of image editing tools you can use to refine your diffusion results and achieve your creative vision.
- Paint Tool: Paint to select an area, type a prompt describing what you want added to the selected area. Perfect for refining large spaces and objects in your image.
- Erase Tool: Use the brush or lasso selection mode to select objects that you want removed from your images**.** Diffusion will remove and blend the result with the background.
- Sketch Tool: Use a sketch to define what you want added, combine it with a descriptive prompt and see your results added to the image. Best for adding uniquely shaped objects that you want artistic control of.
Other bottom bar tools
- Image Opacity Control: Easily check your work or create interesting hybrid views with the new image opacity control.
- Share and Save: Share or save your creations with just a tap using the scene creation or share button in the bottom toolbar.
Gallery Panel
The new Gallery panel on the right side of your screen lets you view and load your Diffusion results from the past 30 days.
- Rate your images: Tap the 3 dot menu on an image to Like or Dislike it.
- Resizable Thumbnail Previews: Zoom in or out to see larger or smaller thumbnails of your results.
- Select and load past images: Tap an image to load it full-screen (this also returns the camera to that job’s location), tap again to unload, double tap to see the job data. Tap an image’s 3 dot menu and select Restore Camera to navigate back to that image’s location without loading the image onscreen.
Bug Fixes
- Fixed a bug causing triple tap to not work properly (selects all connected elements)
- Fixed a bug that caused a crash when creating tag folders
- Fixed a bug that caused a crash when all materials are deleted from a model file
August 22nd, 2025 - Here’s what’s new in SketchUp for iPad v7.1.1 (2190)
Fixed an issue that caused users to get stuck in a loop on “The Legal Stuff” screen, preventing users from logging into the app.
August 19th, 2025 - Here’s what’s new in SketchUp for iPad v7.1.0 (2188)
In this release, we focused bringing the real world
into your digital model. Check out the new features and fixes below!
Update your app here: SketchUp on the App Store
Add Location improved - Bring your designs to life with enhanced Geo-location and Terrain Data on SketchUp for iPad!
Preview your model in the add location window, toggle a location pin for precise placement, and use the True North offset for accurate sun/shadow studies. Import larger terrain areas with improved data quality, and now include 3D buildings! Users can control building details like position relative to the terrain and building foundations.
Learn more here: https://help.sketchup.com/en/sketchup-ipad/how-use-add-location
Trimble Connect - File syncing is improved!
New sync icons show if a file is available locally (cloud), needs download (cloud with down arrow), has changes to upload (cloud with up arrow), or is always available offline (filled cloud with checkmark). You can now also delete projects and folders directly in the Trimble Connect tab (you must be owner, and the project or folder must be empty).
Please note, the recent files list and Trimble Connect files may take a moment longer than usual to load when you first open the app after this update. This is a one time event.
Along with new sync icons, we’ve refreshed the welcome bar, giving it a new look and allowing you to collapse or expand the entire welcome bar by tapping the accordion icon to the left of “Welcome to SketchUp”. We hope this lets you keep access to past news and learning content while also letting you reclaim more screen space for your recent files when you need it.
Scan-to-Design named scans
You can now name your scans after creating them, and the name will be reflected in both the Outliner and Tag groups of your model, helping you stay organized when scanning multiple spaces.
Bug Fixes
- Fixed a bug that prevented a guide from being created when double tapping a point or edge with the Tape Measure tool
- Fixed a bug that prevented editing of the default face colors from the Default material chip in the materials panel. Now when you tap to edit the default material chip you’ll be taken to Face settings where you can change the front and back face colors. Default face colors are now automatically reflected in the default material chip.
- Fixed a bug that caused the app to crash when using markup mode
- Fixed a bug that prevented users from changing the color of a pen in markup mode
- Fixed a bug that caused parts of a model to disappear when the viewing angle is adjusted
- Fixed a bug that caused the shortcut bar to become unresponsive to docking areas
- Fixed a bug that caused the text of dimension strings to be replaced with black boxes when a scene is created
- Fixed a bug that caused a crash when a file with units set to “Engineering” was opened. We’ve also added an engineering units option to the model info panel.
We hope you love these new features and improvements! Your feedback is invaluable, so please keep sharing your thoughts and suggestions here on the forum. Happy modeling! ![]()
April 8th, 202 - Here’s what’s new in v7.0.2 (2172)
This update includes improvements to performance along with important fixes to ensure a smoother working experience.
Performance and Stability fixes
- Resolved a bug causing the app to slow or freeze when the shortcut bar was visible on screen.
- Resolved a bug that would occasionally cause the app to close when editing a material.
- Addressed an issue where finger presses left a grey selection ring behind on the screen.
- Resolved a bug where toggling the classic graphics engine in the About tab caused user account information to disappear.
- Resolved an issue where Learn Tab videos would be dismissed when switched to fullscreen mode.
- Fixed a bug that would cause shortcuts to stop working until a model was reopened
Visualization fixes
- Fixed an issue where toggling the ‘set sun location’ in an environment on then off, resulted in shadows being uneditable in the shadows panel.
- Fixed an issue where Autoshape Live Components created new materials every time they were selected or configured
- Resolved a bug that prevented the use of arrow keys in the edit material details panel
- Fixed a bug that caused shadows to turn
Your input helps us continually improve SketchUp for iPad, so please keep sharing your thoughts with us here. Thank you for using SketchUp for iPad. Happy designing!
March 13th, 2025 - Here’s what’s new in SketchUp for iPad 7.0.1 (2164)
Fixed an issue preventing purchase of yearly subscriptions in-app
February 25th, 2025 - Here’s what’s new in SketchUp for iPad 7.0.0 (2163)
Update your app here: SketchUp - 3D Modeling App - App Store
Please note: SketchUp for iPad now requires iOS 17.0 or newer.
For a list of compatible devices please checkout the following links
iPad models compatible with iPad OS 17
iPhone models compatible with iOS 17
Explore your creativity with a new generation of visualization in SketchUp for iPad. Photorealistic materials and Environments offer powerful yet accessible ways to make your designs pop. You can see and feel true-to-life materiality to make more informed material decisions and create assets that deepen other’s understanding of your vision. The new photoreal materials and environments join Ambient Occlusion from the 6.5.0 launch to complete a trifecta of powerhouse visualization tools.
Environments
Environments – derived from 360-degree (HDR or EXR) image files – provide a sense of place and a source of light that Photoreal Materials react to. You can use an environment’s ‘skydome’ as a panoramic background, or only use the environment to affect materials. Explore all the details on how to use environments in our help center article here: https://help.sketchup.com/en/sketchup-ipad/environments-panel
- To start working with environments in your model, open the new Environment panel from the right side panels list. Choose from a set of default environments in the Library tab, or import your preferred HDRs (or EXRs) using the import button at the top of the In Model tab.
Photoreal Materials and Material Maps
Photoreal materials are dynamic materials that more accurately convey texture and represent how real-world materials absorb and reflect light. To achieve these effects, Photoreal Materials are made up of a series of texture maps that convey material properties like reflectivity, roughness, etc. Check out our help center article for an overview of Photoreal materials and iPad’s refreshed material editing capabilities https://help.sketchup.com/en/sketchup-ipad/materials-panel
- To start working with Photoreal Materials in your model, open the Syles panel from the right side panels list. Choose the new Photoreal Materials face style from the Face Settings section.
SketchUp Materials in iPad and 3D Warehouse
Building on the new real-time material editing experience we released in our last version, we have a few updates to the In-Model material library tab:
- The 3D Warehouse button in the Materials panel will now take you to a new selection of Photoreal material collections curated by SketchUp.
- You can now save and organize your own materials to your device by exporting and importing individual SKM files. The import and export buttons are found in the top row of the In Model material panel.
- Purge Unused: you can now purge unused materials from the Unused secession of the In Model material library
- Automatic material enhancement: SketchUp can auto-generate metalness and roughness values when you open or import a SketchUp model. You can enable/disable this behavior in Graphics tab of the app setting (gear icon). This is a one time process per material once switched on.
Generate Textures
Photoreal Materials offer new visualization possibilities in SketchUp — but what about all the materials you use today? In this release, we’re introducing an AI service that transforms your classic materials so that they can be rendered as photoreal. With the help of AI, SketchUp will suggest settings for Metalness, Roughness, Normal, and Ambient Occlusion appropriate for the material and automatically update that material within your model. Especially exciting for non-seamless textures, SketchUp can return tileable assets that display better overall.
This ‘AI magic’ is triggered with one click from the Edit Material dialog. Look for the stars icon
in the lower right corner of the material thumbnail.
Live Components Improvements
SketchUp’s pre-built configurable objects, commonly known as Live Components, are graduating Out of Labs and integrating into a new Content Library in 3D Warehouse. In addition to that, the following improvements have been made to Live Components on SketchUp for iPad
- Live Components can now be painted. Please note: LCs saved before the 7.0 release will need to be configured once to enable painting. In order to paint an LC, all model elements must be deselected.
- Improvements to the auto naming of materials used in Live Components.
- Improvements to Live Component connectivity.
Modeling improvements
- Rotate: When the Rotate tool is active, you will now see rotation grips on group and component bounding boxes. These grips behave just like those available when Move is active. Additionally, the Rotate tool’s protractor now aligns with component bounding boxes and snaps to bounding box midpoint grips.
- Rounding and unrounding faces with Arc tools: We’ve made the filet functionality of the 2-point and 3-point Arc tools on 2D faces less hidden. Now, after you’ve created one tangent arc – by creating an arc tangent to edges at both ends – SketchUp will show the availability of that arc at other edge intersections on a face. Double-click to repeat the arc. Additionally, you can ‘unround’ a corner by clicking on the convex side of an arc.
- Snaps improvements: Objects connected by snaps now have an additional context command – Select > Connected by Snaps (and that’s what it does!). Snaps also have new behavior on edges and vertices – aligning to a plane mid-way between adjacent faces – providing more logic for designing sophisticated assemblies. And snaps now have a down-key, parallel ‘magenta’ inference lock!
- Text tool: dynamic values: Measurement values created by the Text tool – length, area, coordinates – will now update when a referenced entity is changed. Similar to how it works in our documentation app for desktop, LayOut. ‘<>’ will appear in text fields, denoting this dynamic value. The ‘<>’ value can also be typed into a text field to return a dynamic measurement if one is available for the text object. Type before or after the <> to use custom text alongside measurement values.
Bug Fixes
- Fixed a bug that caused obj files to crash on export when enabling the ‘export two sided faces’ option is enabled
- Fixed a crash that happened when creating multiple loops using the Freehand tool
Logins
With this release, users will be required to login back into the app via our new landing page experience.
That wraps up everything included in this release. We hope these features help you unlock powerful new visualization journeys, tell your story in richer detail, and help bring your design vision to life. Please send us your thoughts, concerns, and suggestions here on the forums. We look forward to seeing what you create next!
