Just updated to Sketchup Pro 2023. I’m having a UI issue where the measurements value box in the bottom right corner is not large enough to show the actual values I am working with. See attached image.
This happens regardless of if I am full screen or window.
Any thoughts? Didn’t have to worry about this in any previous versions.
I think this issue has been seen by other users. And SU2023 only supports recommended resolutions and display scaling. (If as Dave suggests, you’ve set a custom scaling, change it back to what your system recommends. If this does not work, reduce the scaling and tray again.)
The Graphics info in your profile iswas of no help to us. (Thank you for fixing this!)
