Hobby mihai.s
Preparing a high dense 3D scan (photogrammetry, LiDAR) model for SketchUp
Transform a high-resolution photogrammetry terrain and stone ruins model scan into a low-poly, editable model. A simple and quick method on how to cleanup, repair holes, retopologize a complex model and bake the model and paint textures to transfer high-res info from the photogrammetry model to the low-poly one using Blender.
  • Removal of noise shells, spikes, intersect faces and repair holes in the model using the trio of extensions from SineWave;
  • Retopologizing the high poly model using J-Remesh;
  • Unwrap Low-Poly Model;
  • Setting up a Shader (Texture);
  • Baking the Diffuse Texture (and others, like Bump, etc.) using SimpleBake;
  • Auto generated low poly mesh with baked texture;
  • Cleanup: Painting/Repairing ‘Gap’ or Holes in the Texture;
  • Exporting the low poly model as a DAE file for SketchUp;
  • Importing into SketchUp the low-poly model, that is much simpler and easier to edit and use, that looks almost the same as the high-resolution model.
Starting from this post about ‘creating a landscape’
Creating a terrain using a point clouds in SketchUp, starting from a photo (2D plan) with a few numbers.
Extensions:
  • Point Tool;
  • Tape Measure Tool;
  • Fredo TopoShaper.
Startig from this post about ‘piles of rubble and materials’
Creating piles of objects (physics) in Blender, imported in SketchUp
Modeling an organic shape for a swimming pool (SUbD)
Starting from a post about a ‘crate
Modeling a Euro Crate in SketchUp (Web, Make, Pro)
Starting from a post about a ‘rebar
Modeling a rebar (SketchUp and LayOut ready, low poly)
Starting from this post about ‘draped fabric’.
Modeling a draped fabric, using Fredo Spline and Clothworks extensions
Starting from a post about ‘modeling a stone wall
  • turn perspective into a front view in Affinity Photo (or Photoshop, GIMP, etc.)
  • draw over boxes in Blender (or in SketchUp). UV unwrap and UV map those boxes/stones, using the original photo or another texture;
  • adding details to the stones in Blender, using an extension (Wear N Tear, OCL, etc.)
  • exporting as DAE and importing into SketchUp (as a low poly model with PBR material)
Starting from this post about ‘cleaning up an imported model
One method of Fixing/cleaning up random diagonals and reversed faces for ‘3ds Max to SketchUp’, via Blender
Starting from this post about a ‘text and drape
Using Intersect Faces
and… there is one :wink:s4u Select
Select faces by area, select edges by length… and more
Testing RealityScan app @ #3DBC2024
:slight_smile: Good idea, Pierre (@ateliernab)! Thanks!
Scuba suit
Rigged and animated :wink:
With a specially created photo (in T-pose), you can easily generate your animated 3D model using AI.
Replacing raw geometry with components
Thank you this seems a very useful plugin. However it looks like it will only work if the stem geometry is singular as per the example shown in the video. I have downloaded many trees and plants in the past with multiple stem geometries which are not connected, and when I use Select active with selected materials all geometries are selected and then it is extremely hard to deselect the stems of a plant or tree which are in the middle of a large tree or plant. Does that make sense?
What I am after is to select geometry which has a particular material attributed with it, but I cannot seem to find such a method
You’re welcome!
I found that tree in 3D Warehouse and only used a branch from it for illustration, but if you have a specific model, I can look for a solution.
Starting from a post about ‘showing dimensions’
Show dimensions when scaling an object
Starting from a post about ‘modeling a table
Method 2
Modeling a table (using quads and subdiv)
Based on the post of Mr. Coolidge
3D model template :arrow_down_small:
Generating a dodechadron (not a tutorial)
Ok, that’s really slick!
