I'm having trouble using sandbox in creating stone/rock walls
Hi guys! Any idea on how to create stone/rock walls like this?
hello, i’d draw it in 2d first, perhaps in autocad, then import in sketchup, use joint push pull and roundcorners.
Or use a texture.
Maybe you can draw it horizontally using the Sandbox tools, then rotate it to be vertical.
Make them as push pulled rectangles then play with Eneroth Erode plugin.
You could also use SubD and Vertex tools.
You can also try the Freehand tool. Trace or draw out the stones with some movement and variation. Extrude. Then round corners or subdivide and apply texture.
Can i ask what extension did you use to round corners??
FredoCorner, formerly called Roundcorner
@eric-s ,
Those are 2 separate extensions, both from Fredo. I use roundcorner…
