Hello community,
May someone kindly advise on the easiest method to model this table pic attached. I have a skp with the dwg too.
many thanks
Hello community,
many thanks
Follow me, some solid tools.
I’d have to play around with getting the wave shape integrated - but @box or @mihai.s will likely be along and have this figured out in a 30 second or less animation.
Bed time for me, so no.
joint pushpull and some bevel tool might help as well
the top can be made using simple pushpull tools. rounding the bottom part can be made using a follow me, it’s probably simpler with bevel or a similar fredo corner tool.
(the hole can be made using solid tools)
for the bottom…
I kinda start the same way, then using normal tools and tools on surface (fredo extension) draw the contour of the raised part. and then a joint pushpull (fredo as well)
can it be done without any extension ? yeah. sure. everything can be done. instead of using tools on surface for the corners, you could draw it line by line face by face. instead of a joint pushpull you could duplicate the parts and scale them up a bit. it all depends on the level of precision and realism you want.
someone else will probably come along an idea ![]()
(back to work now. cheerio.)
thats great, unfortunately plugins are not an option i can only use basic tools with my setup
