Hi - Just installed SU 24 and Enscape 24, using with Mac OS Somoma. I have 32gb unified memory so should be ok and capable. Every time I try to plot the lighting out it crashes. I’ve tried with and without the Enscape window open so it’s not having to render in real time, but I can’t actually put 1 lighting source in place!
any help welcome - I’m new to both.
thank you
Apparently Sonoma is having issues with the graphics card settings.
1st, try setting the “Multisample anti-aliasing” setting to “0x”
2nd, try going back to the classic OpenGL graphics engine.
really helpful @ArchyVR - I’ll give it a go and hopefully I’ll have some luck.
much appreciated
sadly no difference - still crashing as I lay the first light down!
thanks tho!
Too bad, how about reinstalling both SU’24 and Enscape?
thanks I’ll try it - slightly loosing the will this evening, might give a go in the morning!
thanks again
Enscape says the light object must be within a group within a component (until they get the issue fixed.)
well no, on that one, the fault resides with enscape , nothing to do with sonoma.
no need to lower the AA or rollback to the classic engine here.
Thanks for this too - interesting one, does that mean it’s a bug known of already?
Thanks for sharing
Thanks for replying - I’m trying every which way at the moment!
it is a known bug, as mentioned in the link in my previous message, the Enscape devs are on it.
Continuing the discussion from Sketchup 2024 Crashing when adding lights :
DEACTIVATING THE CLASSIC GRAPHIC ENGINE WORKS FOR ME ON SKP 2024; NO CRASHING, ADDING ESCAPE OBJECT LIGHT INSIDE OR OUTSIDE OF A COMPONENT OR GROUP.
HERE IS THE RESPONSE FROM ESCAPE SUPPORT
Hi Dario,
Thank you for your reply!
We’re raising this as a high-priority issue since it’s affecting so many users. We’re tracking all cases internally and hope to have a fix as soon as possible.
In order to mitigate crashes while…
