I saved it to my computer’s working folder.
I am using Windows 10 system.
Please add ‘Windows’ to the operating system in your forum profile.
Ok, add.
jjlibrodo.fosd,
The file you provided (loyola23.skp) does not contain any Sketchup related data! Do you have any sort of backup file that you would like me to take a look at?
camargooliveira1995
There is a large section of data it he middle of your file that has beep replaced with zeros. Do you have any backup files that could be used to recover the missing data?
Yes, I do, but when I try to recover from the backup, the same message “failed to open document” appears
You might as well up load that file. Occasionally I have been able to reconstruct a complete Sketchup file from the bits and pieces drawn from several corrupted files.
How can I do this?
There is a big chunk of the middle of the file that is filled with zeros. You should look to see if there is a backup file, or any recent versions you have saved somewhere else.
i have already used the skb, and changed to skp. i also saved into another file and lower version because i thought its just a version thing.
same thing “failed to open”
Follow the file SKB link
That one is missing the same amount of data as the SKP was missing.
Please help me, Same Problem. I have a Submission in two Days
Don’t spam the forum.
solved (or at least in progress) here
so people don’t try to double solve it.
hello everyone, I have the same problem… last night i saved my file, closed it and today it doesn’t even exist… i only found the skb file and it won’t open. but the weird thing is that even all the exported rendered photos with JPG format are also lost and nowhere to be found. could anyone help me with that please??@colin it’s urgent…please help
Was the file on a service that you are not now signed into?
I couldn’t recover anything from the SKB file.
no, it was saved on the D disk on my pc, and then disappeared i only found the skb file i can’t find the skp file anywhere.
Even my sketchup file is not opening. @colin please help me with this.
File link : INTERIORS 1.skp - Google Drive
