"Falha para abrir o documento" - Algúem consegue me ajudar com esse erro?
Boa tarde. Até ontem esse arquivo abria tranquilamente. Ao tentar abrir ele hoje, recebi a seguinte mensagem: “Failed to open document.” Será que alguém consegue me ajudar a recuperar? Estou nesse projeto há mais de um mês… Obrigado desde já!
Segue o link do arquivo:
I was able to open your file. It’s no wonder your comp;uter is choking on it with all that geometry. There are lots of reversed faces that need correcting.
Plenty of incorrect tag usage …
Screenshot - 5_24_2023 , 1_50_45 PM
… and unused stuff that should be purged.
Screenshot - 5_24_2023 , 1_52_39 PM
A few excessively large texture materials, too.
After that cleanup the file size is reduced by 78%. It’s still a huge file that could stand some more cleanup but maybe your computer will handle it. As soon as I get ituploaded somewhere I’ll post a link.
Here’s the link to the purged file.
Before you try to add more stuff to it, clean up what’s there. Simplify the geometry, correct the reversed faces, etc. No point in adding more to it and making your computer struggle again.
Olá! Consegui abrir. vou fazer a limpeza. Muito obrigado mesmo!
Hi, I’m having the same problem opening a file. How did you manage to open the file?
Just patience. Evidently my computer was able to handle it. If you want me to try with your file upload it and share the link.
Oh, thank you so much! Here’s the link with the files: SKETCH - Google Drive
Unfortunately yours are worse than the OP’s and my computer won’t open them. Do you have the .skb backup files?
Thanks for trying! Unfortunately, I don’t have the backup file anymore.
i tried to open it on windows and macOS but neither succeeded, maybe @colin could do something.
The link seems not to be there anymore.
bom dia minha gente! tenho problema para abrir o meu desenho, alguém pode me ajudar
Necesitas compartir tu modelo.
poderias me fornecer o seu telegram para disponibilizar o arquivo?
https://drive.google.com/file/d/1ne0ga8HP99IfDINTdJsY0fj29QqdfN05/view?usp=drive_link
Estou com o mesmo problema, alguem consegue me ajudar por favor?
link do arquivo
Hey!! I have the same problem, can u help me to fix that?
Please don’t double post. It just creates confusion.
I tried to open your file but couldn’t. Maybe @colin will have some luck if he has time to look at it. I suspect that it is damaged and at least some of it is unrecoverable so don’t hold your breath.
A chunk of the end of the file is filled with zeros, which makes it very hard to recover anything from the file.
The good part is that the file opens, but you put a lot of high poly components in it from 3D Warehouse and you ended up with 16 million edges and 9 million faces and 1 GB, so you will have to be patient for it to open, without clicking on the screen during this time.
