SketchUp 2023.1: Shortcuts using SHIFT + number are no longer working
Hello everyone! In previous versions of SketchUp, I had set up some keyboard shortcuts like shift+1 and shift+2. However, after updating, they stopped working. I tried reconfiguring them, but to no avail. Additionally, I’ve noticed that the shortcuts on the numeric keypad aren’t functioning either. Has anyone experienced something similar or have a solution?
Hi, I’ve experienced the same issue. I would love it to work as it did…
I unfortunately don’t have the solution. Thank you for posting.
There is a long discussion about this elsewhere. I added a reply:
Thank you, Colin. It’s great to hear that you guys are already on it. I appreciate your efforts and will patiently wait for the fix.
Do y’all have an ETA for the Shift+Fix?
Not yet, and when I do know a date I won’t be able to tell you, unfortunately.
There will be a day when I tell you it’s ready now.
Greetings,
The newest version 2023.1.340 - shortcuts have not been fixed!
Still the issues with SHIFT+… keyboard shortcuts that do not work at all!
Hello!
My problem with SU2023 pro might be about the same. If I select an object in the outliner, no key-related functions work; Delete-key do not work, Ctrl+c do not work, Ctrl+v do not work. If I select the object with the select tool in the model, there is no problem (except the clutter in a large model). My SU2022 pro works fine in this aspect, and I’m seriously considering switching back.
