Skalp, live solid section tool for SketchUp
Today Trimble released SketchUp 2019
And yes there is a new Skalp version available for SketchUp 2019. This new Skalp version which only works with SketchUp 2019 can be downloaded from our website.
Do I need to buy an upgrade?
If you have an active Skalp Upgrade, Maintenance and Support you are can use your old Skalp license code to activate this new Skalp version. If your Maintenance is expired (with every new Skalp license 1-year Skalp Upgrade, Maintenance and support is included) you will get the option to buy a new Maintenance when you try to activate the new Skalp version with you license activation code directly from inside SketchUp.
What’s new in Skalp 2019:
  • We support the new SketchUp 2019 linestyles for our Rear View Projection. You still have the option to use our own Skalp linestyles.
  • Every Scene can have a different line style for the Rear View Projection when you use the SketchUp linestyle system.
  • When you don’t like the speeddown when using Skalp you can switch during modeling to the SketchUp Section Fill system. Just switch back when you want to see the full hatched Skalp version. At this moment the Section Fill Color is fixed set to Dark Grey when using the SketchUp Fill system. All other Skalp feature stay working when using the SketchUp Fill system.
  • We worked very hard on our export options:
    • We now also have the option to export to DWG
  • We support DXF/DWG up until version 2018
  • We support different Rear View Projection linestyles in the export.
  • You can now also export non-Skalp scenes
  • You can now select which scenes you want to export.
  • We now support lineweights for the Section Cut Width in the export
  • We now support truecolor instead of indexed color
If you find any bugs or strange behavior please contact us at support@skalp4sketchup.com.
The Skalp Team
