Render your Sketchup Model in Blender
After several years using V-Ray to render my Sketchup models, I make a decision to render all of my Sketchup models in Blender, why? Because it’s totally free!!!. Both of Cycles & Eevee are very great built-in blender render engines.
The only problem that i found is Blender doesn’t have feature to import Sketchup files. Exporting the sketchup models to .dae, .obj or other formats then import it into Blender causes some problems.
But now i’ve found the solution, there is a Blender Add-Ons named Skp Importer that can import Sketchup models with all of the materials nicely.
CHECK THIS OUT! It’s compatible with Blender 2.8 & 2.90
Old way how to do that.
My latest work
MAKING OF HOUSE V
Making of House V is on Youtube now!
Feel free to subscribe my channel CG Juicer. Thanks.
SketchUp to Blender 2.8 Compilation on Youtube.
SketchUp to Blender 2.9 on Youtube
Ekrānuzņēmums 2020-09-17 163622
Same with Blender 2.82a and 2.90. Where’s the problem?
@kamambers Release SketchUp Importer v0.21 (for Blender 2.83 LTS) · arindam-m/pyslapi · GitHub latest release for Blender 2.8 & 2.90
Very solid renders :+1: - are you having to do a lot of UV work to get the materials to map properly? Or are you finding that as long as they sit right on the SketchUp model they look ok in the renders?
@arbinsidik thanks a lot! This release works with both Blender versions very good.
Wow Justin, thanks!
I found that this add-on exported materials nicely, what I get in Blender is look the same as what I look in SketchUp, so I don’t have to do extra UV Work in Blender if I’ve done it in SketchUp. But in some cases, I do UV Work in blender to get different look for some skp component objects.
Look at the wooden roof :
You should look at the Substance for Blender plugin it works well as a find and replace material editor for the SU files and you dont need to open anything in substance painter (but you do need a license key).
It means I can directly add substance materials to sketchup models in Blender in a few seconds without opening any of the substance apps. Use Substance files (SBSAR) inside Blender 2.81 (install & use) - YouTube
Lol - as if I needed more new stuff to learn on my list :stuck_out_tongue:
Does this means sbsar file parameters that can be tweaked in blender too?
I have to take a deeper look at blender.
Edit: stupid question, I made it without seeing the video first. That’s exactly what this does. Great stuff
I successfully imported my SU files (2 of them) into Blender. One other though failed, it only imported a small portion of the model? I suppose it might be the size perhaps? Drawn to scale its nearly 400m long and the actual dae. file is 140 mb.
@trampy thank you for your reply. I’m not sure if 3ds will work on my Chromebook, I will try it though. I did notice though with watching a Youtube tutorial for Sketchup to Blender that you need to rescale your model? Is that correct?
@trampy I think I worked it out. I added the ‘clean up’ extension for SU and now it seems to work fine. All I need to do now is get more experienced with Blender. Thanks so much for your help Trampy.
@trampy that would be wonderful if you could. I haven’t had much success with watching the Youtube videos…they go so quickly :roll_eyes:
That will be some amazing help Trampy. One of the major issues I am having with working on large models is setting the lighting and camera. I’ll go through those videos as I can; like you my time is limited each day.
I’ve been playing around with the camera settings and angles. The problem I’ve been having is that when I go to render, the image I get is often only a 1/4 of the actual model.
please use the Blender forum and create a topic, there. The way discourse forums work is that it is actually one big pile of posts and mixing problems from other software messes things up for users that are looking for their problems with SketchUp camera settings.
sign up here:
you can try reading these if Video tutorials are not your thing .:
Blog - Artisticrender.com ( articles section)
He has a book also .ArtisticRender's Blender e-book
love your buildings. love the tip.
Yes its very good, especially for adding post process effects such as glare and colour grading!
Wouldn’t it be great to be able to have import or export native Sketchup files into Blender working across platforms and operating systems.
I posted this the other day in the hope someone might be able to help.
Thanks in advance
