He used VertexTools from Thomthom.
Thanks!
Thanks @Cotty, it is indeed Vertex tools, one of my most often used tools.
If you mean freadoâs excellent Box Twisting, part of Fredoscale, then No, it would give a very different result.
Fredoâs tool will slice the shape and make it curve, when subdivided it will tend to remain square and it doesnât retain the quads so the SUbD is messy.
Vertex tools rotates the faces keeping the lines straight and maintaining the structure so that SUbD has clean quads to work on.
Yees, and I showed you that what you had suggested wouldnât work in this case.
Can you not see in the gif the different results, the one on the right doesnât form the fan shape when SUbDâd.
In the context of the question you were answering, the answer is still, No, in the case of creating this shape in this specific format, ie; a fan blade made using SUbD, fredoâs Box Twisting isnât appropriate.
ok fredo wont twist it. nevermind.
Youâre missing the point. I donât care how Fabulous I am, you answered a question incorrectly, I corrected that by showing you why your suggestion doesnât work in this case.
Fredoâs box twisting will twist things, but it wasnât the tool I used and it wouldnât have worked even if I did use it.
I give up.
You pointed out another plugin that can be used to twist things.
I showed you how that specific plugin doesnât work in this specific instance. I didnât chastise you or anything, I gave a demo of what happens with both options.
You insist your answer was relevant.
I point out that it wasnât relevant in this case.
You get upset and delete everything.
Why? It was useful information on how certain plugins, while capable of doing virtually the same thing, donât work in combination with other plugins.
This is a note to all contributors to this thread.
Sometimes the continuity of information in a given thread becomes disrupted or somewhat confusing when posts are deleted by the authorâŚso in the future please consider how eliminating a previous post may affect the way the information is presented. There are times when it may be preferable to edit posts rather than to delete them entirely.
On a lighter note, good stuff Box, keep it coming.
After a brief cooling off period, hereâs a bit of fun with Thomthomâs new plugin True Bend.
I think my laptop would die trying to load a model that complex! Donât even want to think about actual render timeâŚ! ![]()
You might be surprised, I did this on an i3 that is more than 10 years old.
But yeah, it did struggle a bit.
Box, Great stuff. I love how you also give very good gifs to demystify these âsimpleâ actions to create complex stuff.
Whatâs the convert paths to cylinders extension you use when making the chairs?
Nevermind I hunted about and found it in the Sketchucation extension store. ![]()
Cheers @IanR
It was Didierâs old Lines2tubes if anyone else wants to know.
Iâve found that when I have a bash at rendering it often looks fine in the program. Then when you put it against the bright white contrast of this forum, it suddenly appears very dark. So now I always er on the side of lighter, itâs a bit of an art finding the balance.
My problem is one screen is bright and one screen is dark, so if I render on one it gets washed out on the other and vise versa.
I suspect my dark screen is close to how it should be and this was rendered on the light screen, so it looks dark. I often have to check the image on my phone to get some idea.
