Numpad decimal separator input not localized
I am using the French version of windows 10.
The decimal separator in French is comma: “,”.
In SketchUp the decimal separator is localized, so SketchUp uses comma as a decimal separtor on my system.
In most localized applications, eg. Excel, the dot “.” key from the numeric keyboard inputs the localized decimal seprator (in this case a comma).
However, when I type a dimension using the numeric keyboard in SketchUp, it is a dot instead of a comma that is input. This renders the dimension invalid, and I have to edit it and insert a comma from the “regular” keyboard area. Very painful!
If this can’t be fixed, is there a way for me to switch to English localization for SketchUp?
Hi Geoffrey, hi folks.
I have signalled this since version 4 or 5. On PC, the dot on the numerical keypad works as you describe. On the Mac, there is no problem. On Mac, SketchUp behaves as Excel and other softwares and transform the dot as required to a comma if the regional settings are set for that.
Regards.
Jean
Yep, 2024 version here and it is still a problem…
yep. windows doesn’t force any software to apply the user’s choice. I have a couple of softwares, including notepad, who will see it as a dot.
here is the solution I found.
there is an official microsoft tool to make a custom keyboard layout. I started from the standard french, then I changed the decimal separator key to a plain comma.
