I added an object from the 3D warehouse to my layout, which ended up being HUGE when I placed it, I then accidentally ended up zooming out way too far, and now can’t find it again. I have tried the zoom extent tool, and also copy and pasting the objects onto a new file (as seen on another thread) and neither has worked. I’m quite new to this and this is my first project, but I have spent a long time on it and would hate for it to be lost…
If you really want to use those books from the 3D Warehouse, download them into a separate file and scale them down before adding them to your main model. In fact you should always download 3D Warehouse components into a separate file. Check them and make sure they are suitable for use. If not, fix them or hunt for a different component.
After deleting the books component and hitting zoom Extents, I see this.
Okay thank you for the tip about downloading components! I think my layout my be inside that outerskin of the van, strange how that has come up! (I pressed unhide to try get it back so maybe it was hidden)
The books are very complicated too, and use a lot of images. I optimized the geometry a bit, but the file is still 15 MB because of the textures. Here’s the books, optimized, and no textures.
Thank you so much for your advice! From now on, I will import first to another blank file and make sure it’s ok before placing it to my project.
I wish that I knew it before, now my project is zoomed out near to infinity that even Zoom Extents doesn’t work and I don’t know what to do…
You should really upload the .skp file as it will be the latest version. You uploaded the which is a baackup. I’ll see what I can do with it though. Hang tight.
