Hi,
I want to set a max on LenY scaling 605cm. When it is bigger it sets it to 605cm, if smaller than set current lenY.
=IF(Current(“LenY”)*2.54>605,605,Current(“LenY”)*2.54)
Unfortunately this won’t work.
Tuinkamer compleet v0.5.skp (7.3 MB)
Hi,
use for values between 50 and 605
=largest(50,smallest(605,current("leny")*2.54))
a min value allows for posts…
Thanks, I implemented it. But my sketchup seems so buggy.
It jumps when I scale it and it won’t go to the 605 cm.
Here is the model…
Hey, spent some time on this and did not manage to fix it. Couple observations: There are still a lot of IF statements with no else, which may affect stuff/cause some weirdness. Second you are trying to scale a DC inside the parent it has references to, I am pretty sure this always causes problems. 3rd you might consider 3 separate sliding door panels that hide or show, it would simplify the positioning and rotating a bit maybe. That said I am sure Philip will have helpful insight this evening… good luck.
I have checked it again myself. I find it really odd. I think it is a bug.
When there is no function it behave normal when scaled.
I have made a work around. further automation.
I calculate the gap width a make the component this width.
That sounds like the right approach, everything should configure from parent down… Here is a great list of DC bugs:
And this one caused me a bunch of grief as well:
