Loading, opening new file very slow since upgrading to 2017
#1
Since upgrading to 2017 (fresh install) it takes much longer to run File > New or open an existing SKP file. Even small files can take 20-30 seconds or more. Larger files hang for closer to a minute. 2016 didn’t have this issue for me. I’ve still gor 2016 installed and it does not have the same problem on the same machine. 16 opens files instantly.
#2
When you installed SU2017, did you install it properly by right clicking on the installer and choosing Run as administrator?
#3
I don’t think I installed as administrator. Can you explain why that would have this effect?
#4
Because SketchUp has to make some changes that require it be installed using Run as administrator. And being listed as Administrator isn’t sufficient, either.
Also see this: Important Update on a few Potential SketchUp 2017 issues on Windows
Make sure your graphics drivers are up to date, too.
#5
I’ve customized my watermark and a set of materials as well as my preferences. Can I reinstall over my current install and keep all of my customizations?
Thank you for your response, by the way.
#6
Yes. When you run the installer again using Run as administrator, it’ll give you the option to repair the installation. It won’t overwrite anything in the User/AppData/…/SketchUp directories.
#7
Thanks. I think my graphics driver is not up to date either so trying that first.
#8
Definitely repair the installation because it isn’t correct if you didn’t use Run as Administrator.
#9
Will do. Just want to update the graphics drivers first. I have intel graphics and this seems to be a known issue with those based on your link.
#10
Repair install as administrator didn’t fix the problem.
#11
It will have fixed other problems you haven’t run into yet.
What about the graphics drivers?
#12
Updating graphics drivers appears to have not had an effect.
#13
