My request is to have the change in dimension leader direction be detected, and respond
by adjusting the alignment of the text accordingly. Attached is a video showing the extra step that has to be taken every time dimension text with a leader attached is moved.
Good Feature requerst.
Sounds like a reasonable fine idea to me as a default behaviour.
Any control over text & leaders is welcome since it can make all the difference in a particular situation, even if it’s not something we’d use every day.
Similar/related topic…
There was some discussion about changing the Text Box element to automatically Shrink to the size of the text.
Would that be a better solution?
The text box size can still be edited manually if you wanted a consistent size across your text boxes). Perhaps the option would need to be turned off or on.
