Layout '24 Leader Text
Hi all,
First, thank you to everyone involved because layout is dramatically improved from previous versions.
However, in the new version of Layout the leader text appears to behave differently.
I am running into an issue where the horizontal leader node will rotate on some but not all of the leaders I have placed. I just have to delete the broken text and place a new one, then it will behave normally unless it is copied a few times and then break again.
Can anyone point me in the direction of anything to make sense of it?
I am running the Experimental Graphics Engine with Draft Mode disabled.
Thanks!
Edit: It has to do with the Experimental Graphics Engine, turning it off fixes the problem. I have been toggling it on for setting viewports and bounding boxes and then turning it off for placing text.
