Been using SketchUp and LayOut for the last 3 or 4 years or so. Sketchup runs great for the most part, but its getting to the point where LayOut is unusable due to its slow speed and response time. For instance, simply rotating an object has a lag of about 2-3 seconds.
I built a computer specifically to run Lumion, so I know my hardware is fine:
Intel i78700
GTX 1060 6GB
16 GB RAM
After reading some of the posts on this forum, I am just at a loss. I use scenes for everything, groups and components, etc. I am not a beginner when it comes to either program.
The file size of the model in question is only 24 mb.
Any thoughts? Are there any settings I can change to make LayOut run like it should? I cannot be the only one experiencing this.
Unfortunately not. The file doesn’t seem to matter, LayOut seems to be “bogged down” if there is a large .SKP file attached to it.
I broke down the part of the file I needed into a smaller .SKP file and that seemed to do the trick. It’s still very disappointing that LayOut can’t seem to run correctly with a large file “referenced”.
You’re probably aware of the various options available in LO to improve performance and SU modeling techniques to make the workflow from SU to LO as optimum as possible.
Also updating drivers, etc.
I’m not much into the specifics of hardware so can’t comment on your specs.
How many faces and edges (with the nested components option enabled)? If a 24 MB file has many instances of heavy components like 3D plants or cars, the count would typically run into many millions. Faces and edges are what affect SketchUp or LayOut performance and the file size is of secondary importance.
Many of my SU files are below 10MB, even below 5MB.
I’ve trawled through some past projects looking for large SU files.
Going through them after purging them of components the file size is much reduced.
Many of my models get larger than 10MB if I import furniture and fixture items from the Warehouse.
I once created a model where I imported a roof tile from the Warehouse and had, perhaps, a couple of hundred instances of it in the model. The LO file was incredibly slow and it took me a while to realise why!
In LO>Document Setup>Paper there is the option to set the Display Resolution. Also there’s the auto render setting for viewports that you could untick.
Update: I “upgraded” to Sketchup 2020 and still no change. This time I am importing .jpg files (someone else’s drawings) into layout to red-line and make changes. Still extremely slow.
