Good day : ) I’m on a Mac with 10.11.1 and sketchup pro 2016. I’m having a problem when exporting from Layout into pdf, the document seems to be moved about 1/4" up on the pdf version. My document has a solid color background and when exporting I’m getting a 1/4" white band at bottom of page.
OK. All I did was open the LO file and make the export. I wonder what is different between you doing it and me doing it. I think we need a member of the LO team to chime in here.
I just quit LO, opened file again and exported with different name and still the file seems to have been bumped up 1/4" showing the white band at bottom of document.
I don’t see the problem on Yosemite but I see it on El Capitan. As a workaround, the following steps worked for me.
File->Page Setup…
Choose “Any Printer” from the “Format For:” menu, then choose “Manage Custom Sizes…” from the “Paper Size:” popup menu. 3) Click the ‘+’ to define a new paper with Paper Size: 8.5 by 11 in, and set all margins to 0 for the User Defined Non-Printable Area. Click OK to save and dismiss the Page Setup dialog.
File->Print…
Click the “Show Details” button if the Print dialog is not showing the expended detail panel.
Select “Paper Handling” from a drop down menu.
Check the “Scale to fit paper size” checkbox. Now the “Destination Paper Size:” menu right below it is enabled. 8) Select the custom paper that was defined in the above step 3.
From the “PDF” popup menu at the bottom-left corner of the dialog, select “Save as PDF…”
Thanks Wei, that work around worked for me. I have a lot of these files to create, it would be ideal if I could find a fix for the problem when exporting to save steps/ time.
