Auto-Text is only showing dynamic component attributes that have a label (i.e. that are visible in the component options window). Is there no way to get it to show all the other dc attributes?
Is there a way to show a few attributes, one after the other, with one Auto-Text entity?
Hi Mike, but the attribute must remain visible… I want to reference attributes that the user cannot see.
It’s complicated….![]()
The DC dictionary can only display attributes that are set to visible and thus visible in the Options dialog.
I have once investigated adding own dictionaries to be available in LayOut, but only succeeded in adding .skc’s to pop up in LayOut, check this post:
Thanks, I see. Though then instead of the DC labels you have skc info visible in the Component Options menu.
I think I found a workaround with one of our flextools DC patches that hides labels! It didn’t occur to me to use it until yesterday. The script hides labels only from the Component Options window but not from Layout luckily.
Hello @MikeWayzovski, I know it’s an old topic, But I would like to ask you a question: why your recommendation does not work using the attribute “material” in the behaviors section. I already tried your recommendation with a new attribute and it works.
Thanks
I think I found a solution, I created two attributes, material and one custom. the latter referenced with material (=) and left them visible to users. The only problem is that it does not update automatically, to do so, I have to go to the custom attribute and go to the display window and click apply. After this it is updated and is available in Layout.
If you have a better alternative let mi know.
Thank you, again
