I’ve been scrolling the internet the past weeks, but can not find any solution. So I hope someone can help me!
This is the main problem: I’m working with Dynamic Components and I need to make a Layout Drawing with numbers of the components (not all components, but the ones in a specific layer). These numbers need to match the numbers, shown on the SketchUp Report.
Now I’ve got a few possible ways in mind, but I’m not sure if they’re possible.
Use the Rename by Layer plugin (renaming the instance number) → this Instance number will be connected to a Dynamic Component attribute (this is what doesn’t work yet) → This Attribute is connected to another attribute that chances the 3D text, sticked to the part → This instance number will be shown in the report.
Use the Rename by Layer plugin (renaming the instance number) → This instance number will be shown in the report → In sketchup layout I will need to put by hand (or automatically if possible) labels to all instances (which is lots of work)
I hope there is a way for possibility 1, because that way everything will be automatic.
Maybe a ruby solution is what you need. I don’t know enough about the Layout API (or anything actually), but maybe pull on this thread and see where it goes…
Thank you! This is good to know but I not really what I’m looking for.
The main problem is that the Instance number is not connected to the Dynamic Component attributes. Is there any way I could create a link between these?
