Voortzetting van de discussie Cotty's gallery images:
Working on a classification:
In SketchUp:
In Layout
Final result:
See attached model with Classification inside Model Info > Classifications
Bouwbesluit.skp (377,2 KB)
@brewsky @RichardMuller would this be usefull?
I take a look at it. I let you know …
Mike!! This is awesome!!! Looking forward to seeing the content you post!!
When you say working on a classification, do you mean you’re making your own classification system? If so I’d love to know a bit about it, the summary of it.
Also check this page:
https://help.sketchup.com/en/sketchup/classifying-objects
scroll to Creating an SKC file.
It is based on XML and the schema is .XSD, if you open the Model Info [menu] Window >Model Info > Classifications, select the classification and then choos export, you can save it on your desktop (It defaults to the %AppData% )
Rename the file (change from .skc to .zip) and then extract.
I use Xcode to edit, but any editor will work.
Yes, you can have multiple tags…
but it is a hassle to label in LayOut
This one has the NAHB costcodes embedded in the embedded SketchUp file(!):
Bouwbesluit.layout (390,5 KB)
Zeker!
Kast Puck.skp (1,3 MB)
Checking how tiles come together…
Nice tiles, wanted them in our new kitchen. The plans changed though…
