I would like to use SU2024 (Mac sonoma) but space mouse is not available and I am stuck with SU2023.
The installation of 3D Connexion stops in the middle of the installation and is in a state of forced termination. I’ve looked for a lot of information and tried the following, as well as technical support information, but it doesn’t work…
I am posting this here because I am having trouble.
Is anyone else suffering from similar symptoms?
If you can tell me how to fix it, I would be very grateful.
Thank you in advance.
Start/restart your Mac in recovery mode.
Or
Disable SIP
NOTES! Please read the notes in the red box. Re-enable SIP in step 6.
Note contents:
Temporarily disable SIP only to perform the required task and re-enable it as soon as possible. Failure to re-enable SIP at the end of the test will leave your computer vulnerable to malicious code.
Restart the machine
Start the terminal (/Applications/Utilities/Terminal)
Run the following command
systemextensionsctl list
(This will display a list of installed/running extensions. The status of the extension will probably be “activated enabled”)
systemextensionsctl reset
(Note: This will also remove any other existing extensions. Probably recommended only if this is the only extension you have)
Or:
systemextensionsctl uninstall 9D93Y2RD6L com.3dconnexion.dext
(Note: This will only remove 3dconnexio DEXT. A final removal of the extension will require a reboot)
The status of DEXT can be checked again with the following command
Important: SIP must be re-enabled.
(Please re-enable SIP.)
You can check the status again in the terminal: csrutil status You should see “enabled”.
