How to select faces loop at once?
Hello everyone,
I am trying to select loops with faces like in the picture I attached. I want to know whether there is a way to select them all at once or if there are any plugins that can do this. Because there are so many reveals of windows and doors that I need to select.
Thank you very much
Possibly Selection Toys: Selection Toys | SketchUp Extension Warehouse
Id orbit the camera to look down on the geometry and drag a left to right selection window around the edges I want to select.
Double clicking an edge will select the two adjacent faces. Not necessarily saving clicks but does save orbiting time :grinning: in x- ray mode…
Select loop of Faces
Hi 3DxJFD,
Thanks for replying. I have tried that but couldn’t get the result what I was expecting. Thank you.
Hi DaveR,
Thanks for replying. Your method can be used but it gets tedius when the project is complex.
Thanks.
Hi MikeWayzovski,
Thanks for your reply. This is a great method. But, I actually want to select the face loop all at once because the time frames given for projects like this are very tight. But this is a great method, I can use this in small projects.
Thank you so much.
Hi mihai.s,
Thank you for your reply and the video you made. This is what I was looking for. QuadFaceTools is the solution.
Thank you so much.
QuadFaceTools Extension :point_down:
You’re welcome!
You can use it in combination with s4u Select, to modify a larger number of doors/windows in one step.
Wow, thank you so much mihai.s :heart: :heart: :heart: I really appreciate your help and the videos you made. I wasted so many hours trying to do this in my projects, so this is a big relief. s4u Select is great. Thank you again! :heart: :heart: :heart:
