How to select faces only
Sketchup has a lot of cool ways to hone in on what you want to select. But if you want to select only the faces and no edges, I’m not seeing a way to do it other than selecting each face. My reason for this is that I want to be able to change colorings on large groups of faces using the Entity Info window. But if one or more edges is included in my selection, I can’t do it.
I read other forums where people suggested
  1. Select the region, with the edges, then switch to wireframe mode and deselect all the edges in one swoop.
  2. Turn off edges in the Styles window, then drag over the faces you want to select.
Neither of these things work. No matter what mode I’m in, dragging to select an area includes all the edges and all the faces that would normally be selected, whether they are visible or not.
Anybody have a method that works?
Can’t see a way to do what you asked, but for times when you only need to change one side’s color it should work (in some cases you might have to reverse faces to see that it worked). Or for doing both sides could you not just do two paint bucket fills?
Check this plugin: Selection Toys .
Yeah that is a good workaround. I can select the region including edges, flip the faces, color the backs, flip them again, and color the fronts.
You also need to turn off profiles.
Perfect, yes that does it, thanks!
You can use also a “bucket” with pressing “ctrl” (Windows).
Cool, thanks, but I’m on a Mac. I think that the method @eneroth3 clarified is the quickest and easiest anyway.
Ctrl = Option
Here is more information about it
Selection Toys is easier and better on the long run :slight_smile:
