Aligning a cylinder to a guideline in SketchUp using Curic Align
Starting from this post about a column
Modeling a column in SketchUp for Web (Free, Go, iPad), desktop (Make, Pro)
Starting from this post about a shape
Hexagon to circle in SketchUp for Web (Free, Go, iPad), or desktop - Make, Pro
This is really great. Thank you for taking the time to do this.
Starting from this post about dwg and faces
Creating faces in an imported dwg file. Once all geometry is properly grouped and tagged (different methods - native tools/extensions), faces can be easily created, without sticky geometry/triple click problems.
The tags are for visibility control, they do not separate the raw geometry in SketchUp, just like in AutoCAD.
Continuing this post about a swimming pool
Beveling the edge of a pool bottom in SketchUp using Offset and TIG Extrude Tools extension.
Starting from this post about Offset
Drawing a polyline (lines and arcs), double 2D offset
FredoSpline and DBur Double Line extensions
Drawing a 3D path - polyline (lines and arcs) and double 3D offset, using FredoSpline and Fredo Curviloft
Starting from this post about ring random grid
Modeling a ring with random grid (quadrilateral tessellation) in SketchUp
Extensions:
- Sandbox
- Random Tools
- Vertex Tools
- TrueBend
- Fredo JPP
- Multiple offset
- JHS Powerbar
Starting from this post about fillet
Starting from this post about render
Rendering a SketchUp model in Blender (very basic)
- set a scene in SketchUp (camera in Blender);
- import SketchUp model in Blender (SketchUp Importer addon);
- set render engine - EEVEE or Cycles;
- add a light;
- change to camera;
- start render
Starting from this post about Product modeling
Topology for Subdivision Surface modeling and UV mapping, with quads
Starting from this post about Select overlapping objects like in AutoCAD.
You can in Outliner or you can use thomthom PickIt extension.
Starting from this post about ‘Product modeling - Gallon with handle’
Native tools: Circle, PushPull, Arc, Offset, Move, Line, Eraser, then SUbD extension
Starting from this post about a bathtub
Brief presentation of the steps for creating the 3D model of a tub with wavy walls in SketchUp. Quads and subdivision modeling.
Extensions:
- QuadFace Tools
- Split Tools
- SUbD
- Artisan 2
Starting from this post about horizontal road over sloped terrain
Hi @Epix3D !
Taking into account that you added your question in a thread about Artisan 2, and the solution I offered you does not involve the use of that extension, I add the method used in my thread.
Steps:
- base model
- duplicate the road and using Vertex Tools to make it horizontal (you can use other extensions for this)
- using Fredo Curviloft to create middle of the roads
- using mc-AlignEnds to conform the middle of the roads over the sloped terrain
- using Vertex Tools to fix the road
- horizontal road follow the slope of the terrain
- using Line to create a perimeter following terrain and the new road
- creating of terrain plots
- using Soap Skin and Bubble extension to create the surfaces of the plots
- geometry of the sloped terrain with horizontal roads
- texturing the new road
- texturing the new terrain
- finished model
