I’ve created a profile for a wheel rim but ‘follow me’ produces a strange result.
wheel_2.skp (248.0 KB)
Too small. Use the Dave Method.
BTW, how are you planning to use this wheel once you have it modeled. If it’s part of a larger assembly you should consider using fewer segments for the circular paths and the arcs in the profile. There’d no benefit in having the over 16 thousand entities you’ll wind up with as your model exists. It’ll just cause file bloat.
