I would like to design an extruded aluminum chassis using standard extruded aluminum sides and separate top, bottom, and end plates similar to image shown here but with removable bottom plate.
What information do you have as far as the shapes of the extrusions? How will you use the 3D model once you have created it?
In general the process would be to draw the end section of the extrusion and use Push/Pull to extrude it to length. If is highly detailed you may need to work at a larger scale or you might use “The Dave Method” to avoid the tiny face issue.
