I need help with resetting all my SketchUp licenses FOR extensions. All of them have reached the activation limit, but some of these activations are associated with old or unused devices.
Datum Level Tool
nz_Descendants
S4Ustair
s4u MakeFace
s4u ImportDXF
@colin I’m having the same issue. Upgraded to SU2024 and now I can’t use the Eneroth Slicer plugin because it says 6/6 activations used. I went back in to SU 2021, 2022, and 2023 and disabled and uninstalled all plugins and nothing changed after signing out and back in. Can you please help? Thanks
I could see the problem, it should work now. If you’re still using Profile Builder 2, that also would have had a problem.
Thank you! that worked. Is there a way to keep this from happening when I upgrade to new versions in the future? Uninstalling or disabling through the extension manager does not seem to affect activations
