Hi
I am working on a Mac.
I am trying to save a new template. I would like to have tick marks on my dimensions lines.
I don’t know how to find these tick marks.
I don’t know how to save them in my template.
When I’m creating a new template I first make a sample dimension to edit. With it selected, go to Shape Style and choose whatever you want for the arrows. Also set the size and the dimension appearance/text placement/units.
FWIW, the tick marks or slashes are added to the ends of the dimension line, not the extension lines.
After you have the dimension looking like you want it, get the Dimension tool, tap S, sample the modified dimension, and then place another one just to confirm it’s the way you want it. Then delete both dimensions before saving your template.
Please correct your forum profile. SketchUp for Schools is web based and used by school children. It does not include LayOut.
Which reminds me to ask, while we are taking about dimensions - @DaveR - how do you change the length of the perpendicular to the dimension line here in red?
Double click into the dimension so you can select the extension line. Then change the End Arrow size in Shape Style. Repeat for the other extension line.
Note that you can do all kinds of stuff with the extension lines. Edit the color of them and make them transparent if you don’t want them visible. Make them dashed and red is that’s appropriate. Make one blue and the other pink. Or …
You need to sample the new dimension line with the eye dropper. Then draw a new dimension.
You’ll need to save a template in LayOut in order the use the style again in a new drawing - you can set up all your line styles, dashes, font sizes and styles and dimensions, then save a template for later use.
Thanks for the YouTube link. Matt’s always great and I learned a lot right there.
BTW, you shouldn’t put email and phone numbers in a public post. It just invites spam and what not. If you want to exchange such info with someone specific, do it in a Private Message (PM) through the bulletin board.
Once you activate a tool and hover over an element in the scrapbook, you’ll notice how the cursor changes in the sampler, there is no need to go back and forth to the sample tool icon.
That’s why I keep my scrapbook on the left in a separate tray, so it’s closer to the tools.
Check this thread:
I don’t know either. Did you reply to an email notification? I’ve never done it that way, so I wouldn’t know. Maybe if you have a signature on your emails, it ends up in the post?
exactly that.
if you enable email notifications, you can answer directly by email, but ALL of your email will be visible on the forum, including signature and images.
