I cannot select a map image any more when geolocating a model. I can select the satellite image and the geolocation works as per usual. Windows 10, 64bit.
Anyone know what’s up?
There was a temporary issue with our map provider, which should now be resolved.
Sorry for the inconvenience.
Bugra
Wow! I just had the error, posted this topic a couple of hours ago, and then you responded and said it was fixed…and it is. I am awestruck! Thanks!!
– Clarke
Continuing the discussion from Error message: "An error occurred while downloading map tiles":
Hi, I am now have this problem. Please let me know how to fix this?
Thank you very much.
-Lam
If you read the thread you will see the last time this was reported, the problem was with the map provider service. It’s likely to be the same thing again. Probably not something you can fix. It’ll need to be resolved on the supplier’s end.
Good to let @bugra know.
What was the location?
"Mensagem de erro: “Ocorreu um erro ao baixar os blocos de mapa”
Fazem uns 3 dias que está assim! como faço p resolver isso?
ou houve novamente problemas no provedor de mapas?
Google translate:
"Error Message:“ An Error Occurred While Downloading Map Blocks ”
It’s been about 3 days now! how do i solve this?
or were there problems with the map provider again?
It’s working here. What is the location of the region you are trying to import?
Ponta Porã - MS Brasil
You need to narrow it down a bit.
Reduzir a seleção da Região ?
Muito Obrigada, agora deu certo
