dmoshi
November 26, 2019, 5:07am
1
Error Loading File C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_advancedcameratools/actloader.rbe
Failed to read RBE/RBS file.
Error Loading File C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rbe
Error Loading File C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_sandbox/sandboxmenus.rbe
Error Loading File C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_trimble_connect/boot.rbe
Box
November 26, 2019, 5:23am
2
It’s generally a good idea to give some more information than just the load errors.
Have you just installed Sketchup? Or has this just started happening?
These are the extensions that come with sketchup so I’m assuming you have just installed it.
Did you install it by double clicking the the install .exe
If you did you may well have permission errors causing your issue.
Find the install.exe and right click on it and choose Run as Administrator and when given the option choose Repair.
dmoshi
November 26, 2019, 5:44am
3
first time in installed Sketchup 2019 pro from the website
i have uninstalled Sketchup and still the same
i did the repair still the same
as SU does’t come pre-installed with PlaceMaker, it either has worked or you downloaded a ‘pirate’ version?
which…
john
Have you looked to see that these files actually exist at that path? It’s pointing to C:/Users/User ← Is that correct?
See this thread …
Error Loading File C:/Users/VasilisPC/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_advancedcameratools/actloader.rbe
Error Loading File C:/Users/VasilisPC/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rbe
Error Loading File C:/Users/VasilisPC/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_trimble_connect/boot.rbe
Error Loading File C:…
… where the poster had a corrupted user profile.
dmoshi
November 26, 2019, 10:12pm
8
I still have the same problem
dmoshi
November 26, 2019, 10:41pm
9
RLGL
November 27, 2019, 1:20am
10
Did you create a new user profile?
dmoshi
November 27, 2019, 1:32am
12
i still get the error loading
dmoshi
November 27, 2019, 1:33am
13
can it be a firewall on my pc
RLGL
November 27, 2019, 1:43am
14
dmoshi:
i think so
You did? Or you did not. this is a yes or no question.
RLGL
November 27, 2019, 2:01am
16
Do you have a legitimate license for 2019 Pro?
RLGL
November 27, 2019, 3:56am
18
Remove SU via Settings add and remove programs. Download a fresh copy of SU. Right click on the new download and choose run as administrator.
dmoshi
November 27, 2019, 4:55am
19
i all ready did that still the same problem
