Error loading plugins
What internet source are you using? I’ve seen problems like that when using weak wifi.
microsoft edge
internet source, not internet browser
Windstream
im using the school wifi
help pliz
From what little information you have given us I would say your school wifi is blocking parts of the installation.
Try downloading using another internet connection.
Or speak to the school IT delegate / teacher to assist with this in specific.
This is what I mean about your lack of information, are you attempting to install Sketchup on a school computer?
im trying to install on my laptop
and I download it at my house to same problem
no matter what I do
install or uninstall ore repair nothing works the same problem that happens load error it’s not loading the plugins
a) did you check if you have access to that folders from the error message
b) did you install sketchup with run the install application as administator
yes I follow it the same way
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_advancedcameratools/actloader.rbe
yes i did do it as admin to iinstall
still the same errors load comes out
Go to the Extension warehouse and download the relevant extensions and install them manually and see if that works.
@Box su_advancedcameratools are installed out of the box by sketchup.
@dmoshi - check the security settings of the files in the plugin folder - looks like the access for the sketchup.exe is not working for the plugin folder - because all out of the box plugins from sketchup reporting the same issue.
Maybe try to run sketchup as administrator.
@tengel07 I’m well aware of that, in fact all the plugins mentioned are ones shipped with SU.
still same problem
error still shows up
I have 19 pro
