Error loading files on startup
I have just downloaded and installed ver 2017 (first time) with the following errors.
Error Loading File C:/Users/dtaylor/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/builder/builder-code.rbe
Failed to read RBE/RBS file.
Error Loading File C:/Users/dtaylor/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/su_advancedcameratools/actloader.rbe
Error Loading File C:/Users/dtaylor/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rbe
Error Loading File C:/Users/dtaylor/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/su_sandbox/sandboxmenus.rbe
Error Loading File C:/Users/dtaylor/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/su_trimble_connect/boot.rbe
Error Loading File C:/Users/dtaylor/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/su_webtextures/webtextures_loader.rbe
I have installed as Admin and ran computer check. Also checked the files and they all all where they are supposed to be but will not read.
I can’t be the only one with this issue.
A little help please.
Thanks, Dave
I have the exact same problem and the various “fixes” elsewhere in the knowledge base have not worked. C++ libraries up to date, installed as administrator, deleted and reloaded plug in files. Nothing helped.
One of the plugins is bad, out of date or not supported in 2017. Disable them in the extension manager and enable one at a time until you find the one causing the issue.
