Enregistrement
bonjour tout le monde, sur la version gratuite en ligne, je n’arrive plus à enregistrer mon travaille.
avez vous une solution?
Translated by Google:
Hard to say exactly why with so little information. How large is the file? Is your storage on Trimble Connect full?
Can you download the file to your computer? Sharing the SketchUp file with us might help diagnose what is going on for you.
la taille fait 81 mo, quand je clique sur enregistrer ca me marque cette page ralentit skeetchup veuillez la quitter ou attendre. alors je clique sur attendre, et au bout de trois fois il me disent que mon fichier n’a pas pus etre enregistre
Again translated by the Goog.
81 Mb is a pretty big file. Very likely save is so long that it’s timing out. Also you could be at the limit of the available storage.
Try downloading the file to your computer. Will that work? If so, upload it to Drop Box or Google Drive and share the file so we can see what you’ve got. Very likely the file size can be reduced to make it possible to save it. You might also need to go into your Trimble Connect storage and clean out some old files to make room for new ones.
je sais pas coment on fait pour le partager ici. mais d’après sketchup j’ai droit à 10GO de stockage
I already told you how to share it. Download the file to your computer and upload it to Drop Box or Google Drive. Then share the link.
Yes, you get 10 Gb of storage. Could be you’ve filled that. I have no way of checking on that with your account but we’ve seen it with other users which is why I mentioned it.
je n’arrive même pas à l’enregistrer dans mon ordi
Try purging unused Components and then purge unused Materials. Then try again.
je vais voir ca
j’ai supprimé des composant et toujours rien
Did you purge the unused components from the In Model Components? Deleting them from the model space does not purge them from the file.
je n’ai jamais fais ca on fait comment?
Go to the Components panel. Click on the house icon to show the In Model components. Click on the Purge button at the bottom. Then do the same for the In Model materials.
ca marche pas
What do you mean it doesn’t work? Did you actually use components in your model?
je croisavoir compris un truc, il faut que j’enregistre petit morceaux par petit morceaux, sinon ca lague trop
I can. What are you modeling?
je suis entrain de modéliser un immeuble de vingt étages, avec 5 logement par étage. une grande maison sur le toit de l’immeuble de deux etage avec piscine et garage. atour du de l’immeuble, petit bar restaurant kiosque, terrain de tennis, de basket, un parc pour les enfants, et un grand parc pour se balader. voiture interdite pour limiter les bruits. tout sera électrique avec des bornes de recharge
This sounds like a pretty big project, especially for SketchUp Free. It would make sense to split that into smaller, more manageable files. It sounds like you have an interesting hobby project.
oui c’est un passe temps mais j’aime faire ca, vous croyez que skectup pourrais tout prendre en compte?
