Any recommendations on how best to organization the Components library? I have been thinking about sorting by type and architectural style.
(Also, Components library is stored within User\AppData\Roaming\SketchUp. Would there be a better and easier place to store it and other SketchUp libraries?)
Create a resource folder and in it, create the folders based on the items you have in Windows->Preferences->Files (minimum: Components-Materials-Styles)
In those subfolders, you can create more subfolders, but I would not nest to deep.
Set the apropiate path in the Preferences and in the Component (or Material or Styles) panel, click on the little blue detail button and choose âopen collectionâ go to the folder and look for the created resource folder.
Once chosen, you can add it to your favorites with the same detail button.
Yes this is the best place (on MS WIndows,) and is called âthe User Resource foldersâ as it is in the user AppData path. However it is actually âŚ
In recent SketchUp versions, SketchUp will automatically enumerate the âMaterialsâ, âComponentsâ and âStylesâ folders in the current running SketchUp versionâs AppData path ⌠and make them available to their respective inspector panels.
This should be unnecessary now. Any folders in the AppData path subfolders should appear in the top level listing in the inspectors now.
This controls where save dialogs open up only, not where the inspector panels look for files.
(The path for âClassificationsâ also controls where the dialog opens when loading a classification XSD file.)
However, it is smart idea to have them syncâd to the same place and only temporarily change where youâd be saving files. (Say if youâll be spending a day creating materials of a certain species and want the save as dialog to open into your âspeciesâ sub-subfolder to save you time. When done with the task youâd reset it to the âMaterialsâ folder in the AppData path.)
For a single user with one setup, maybe. I found it easier to share a (not hidden) folder with collegues or myself outside the AppData folder. A google drive location or server is also not that problematic, since the filesize of materials and components are not to big.
On a single workstation, this would be the %ProgramData% path and I think will also be automatically accessible to SketchUpâs inspectors. (Not to be confused with the %ProgramFiles% path.)
I was just reading a thread last night where reality is the opposite of your opinion. The Guz was saying they were seriously looking into problems with very long startup times ⌠viz:
The threads mentioned do not talk about the file locations of the materials, but only if the panel is extracted upon opening. The autosave and âliveâ saving to dropbox location etc. is about the Model, which location is set to the User Documents folder (local)
Models tend to grow in size, and the size is usually the culprit in the exchange.
Jack Iâm not against what you are needing. Shared resource support has been a long standing complaint and request for better network resource features have been long asked for.
As evidenced by Guzâs posts, they are looking into fixing problems in this regard.
Iâm all for the fixes. And even on single-user systems, it is tedious to have to migrate your resources every time we install a new version of SketchUp.
