window missing when i go to create component, it is opening off screen i guess?
using windows 10
SU2021
using windows 10
SU2021
Follow this guide exactly after “Make Component…”
( Note I assume you have English windows otherwise you may need to replace “M” with a localized start letter, e.g. “L” in French)
In addition to the instruction @dezmo gave you, make sure you have installed Sketchup correctly. That means you right clicked on the downloaded installer and chose Run as administrator. If you didn’t do that, do it now and then choose the Repair option when it is presented.
thank you again that worked perfect
Worked for me too! Thanks for all the support!
I am working with 2 screens and this did not help.
I solved the problem by following the following steps (2 screen solution):
If all goes well you should have your standard window back.
