Cannot connect to net Make 2017 Windows 11
Get this splash screen on bootup of SketchUp, no internet. Is it because I am using Make or is something blocking it ?
Check this and see if it helps.
Keep in mind that services like the 3D Warehouse no longer support SketchUp 2017 Make.
Thanks DaveR I have read through the post and edited the i18n.dat but still get the nag screen.
Is it because I am using Make 2017?
pic 02
Probably due to SketchUp 2017 Make. Or due to the discontinuation or support Internet Explorer by MS.
Oh well life goes on, thanks DaveR
Just been into Windows defender and for some reason it had a rule against Sketchup, removed the rule and hey presto nag screen gone.
Well that’s a good sign. Should keep you going for a little while longer anyway.
I can’t find it in that other topic, but at some point I added a comment about how a trailing / can work in some cases that no trailing / would not work. Meaning, try this:
ONLINE_TEST_URL=https://www.bing.com/
Thanks Colin it was not a SketchUp problem it was Windows 11 deciding to block SketchUp with a padlock in the Outbound Rules.
Another Windows mystery.
