Can you advice how to create this kind of organic form
I mean if you had to recreate this form, what would be your workflow? what plugins you might use? i want to replicate this form as part of series for practise where i look at an image and recreate the form to understand skp better
You need to wait for the file to upload before posting your comment.
What version of SketchUp are you using? That will inform the options for modeling whatever it is.
Complete your forum profile and update the outdated stuff.
wow i cant believe i messed up asking a question. sorry
this is the reference image I’m trying to make.
Im on sketchup 2023
I’d start with a large box and add edges to define the facets. With the radii on the corners I’d probably use Curviloft to generate the facets.
Put that in your forum profile and update the information about your operating system and graphics card.
by facets do you mean the profile shapes we give for curviloft to work?
Also to update my system info, i cant see where to edit it. ill take some time and figure out to update it.
here. that way it’ll take you a minute.
Yes. Outline the edges between the facets. Like these.
Screenshot - 3_28_2024 , 11_31_55 AM
ah so its loft by spline i need to use? will try asap
i was struggling with follow me and this was all i could do
I got results using curviloft skin contour and then using subd to refine some of the curves
wow can i have a look at it pls?
i should probably go watch some more tutorials on curviloft maybe to understand how to do it. :smiley:
Yes. That would be a good idea.
Could you please help me a little more?
i used these lines. could u tell me which ones i should use for the curviloft skin contour.
